projects:crazyflie:index [2013-05-09 16:45] jweather [Using the Crazyflie] |
projects:crazyflie:index [2018-01-16 16:25] bjorn [Development] |
- | ====== Crazyflie | + | ====== Crazyflie |
- | The Crazyflie is a tiny quadcopter often refereed | + | The Crazyflie is a tiny quadcopter often referred |
**Features** | **Features** | ||
Line 7: | Line 7: | ||
- | * Radio bootloader which enabled | + | * Radio bootloader which enables |
Line 16: | Line 16: | ||
+ | * [[doc: | ||
+ | * [[projects: | ||
- | * [[projects: | ||
+ | * [[doc: | ||
+ | * [[doc: | ||
Line 38: | Line 41: | ||
- | * [[projects: | + | |
