projects:crazyflie:index [2013-07-03 23:12] surrender Added safety instructions link |
projects:crazyflie:index [2016-03-29 16:36] bjorn [Crazyflie Nano Quadcopter] |
- | ====== Crazyflie | + | ====== Crazyflie |
- | The Crazyflie is a tiny quadcopter often refereed | + | The Crazyflie is a tiny quadcopter often referred |
**Features** | **Features** | ||
Line 7: | Line 7: | ||
- | * Radio bootloader which enabled | + | * Radio bootloader which enables |
Line 16: | Line 16: | ||
+ | * [[doc: | ||
Line 24: | Line 25: | ||
- | * [[projects: | ||
+ | * [[doc: | ||
Line 32: | Line 33: | ||
+ | * [[doc: | ||
Line 38: | Line 42: | ||
+ | * [[projects: | ||
- | * [[projects: | + | |
