projects:crazyflie:index [2013-10-21 18:57] arnaud [Firmware] |
projects:crazyflie:index [2021-06-24 16:49] kimberly |
- | ====== Crazyflie | + | <WRAP center round important 60%> |
+ | ====== Crazyflie | ||
The Crazyflie is a tiny quadcopter often referred to as a nano-quad, built using the PCB itself as the frame. Developed solely by open source tools and designed with development in mind. E.g. we choose 0603 components (resistors & caps) over 0402 to make it easier to replace components. The voltage regulators are adjustable which makes it possible to change the digital and analog supply voltages simply by changing a couple of resistors. | The Crazyflie is a tiny quadcopter often referred to as a nano-quad, built using the PCB itself as the frame. Developed solely by open source tools and designed with development in mind. E.g. we choose 0603 components (resistors & caps) over 0402 to make it easier to replace components. The voltage regulators are adjustable which makes it possible to change the digital and analog supply voltages simply by changing a couple of resistors. | ||
Line 7: | Line 10: | ||
- | * Radio bootloader which enables wireless [[projects:crazyflie:pc_utils:qt_ui# | + | * Radio bootloader which enables wireless [[doc:crazyflie:client:pycfclient: |
Line 16: | Line 19: | ||
+ | * [[doc: | ||
Line 24: | Line 28: | ||
- | * [[projects: | ||
- | * [[projects:crazyflie:android_client:user_guide|Android client user guide]]: Install instructions and user guide for the Crazyflie Android client | + | * [[doc:crazyflie:client:cfandroid: |
===== Android Environment ===== | ===== Android Environment ===== | ||
- | * [[projects:crazyflie:android_client:dev_guide|Android client dev. guide]]: Development guide for the Crazyflie Android client | + | * [[doc:crazyflie:dev:env:android|Android client dev. guide]]: Development guide for the Crazyflie Android client |
Line 46: | Line 48: | ||
- | * [[projects: | + | |
