projects:crazyflie:index [2013-05-09 15:35] macke [Electronics] |
| - | ====== Crazyflie | + | <WRAP center round important 60%> |
| - | The Crazyflie is a tiny quadcopter often refereed | + | This page has deprecated and will be archived. Please go to [[https:// |
| + | ====== Crazyflie | ||
| + | The Crazyflie is a tiny quadcopter often referred | ||
| **Features** | **Features** | ||
| Line 7: | Line 10: | ||
| * Standard micro-USB connector for charging which takes ~20min for the stock 170mAh Li-Po battery | * Standard micro-USB connector for charging which takes ~20min for the stock 170mAh Li-Po battery | ||
| * On-board low-energy radio@1mW based on the nRF24L01+ chip. Up to 80m range (environment dependent) when using the Crazyradio USB dongle | * On-board low-energy radio@1mW based on the nRF24L01+ chip. Up to 80m range (environment dependent) when using the Crazyradio USB dongle | ||
| - | * Radio bootloader which enabled | + | * Radio bootloader which enables |
| * Powerful 32 bit MCU: STM32F103CB @ 72 MHz (128kb flash, 20kb RAM) | * Powerful 32 bit MCU: STM32F103CB @ 72 MHz (128kb flash, 20kb RAM) | ||
| * 3-axis high-performance MEMs gyros with 3-axis accelerometer: | * 3-axis high-performance MEMs gyros with 3-axis accelerometer: | ||
| Line 16: | Line 19: | ||
| - | * [[projects:crazyflie: | + | * [[[[misc:downloads:index|Download binaries]]: Download links for the binaries. |
| + | * [[doc: | ||
| + | * [[projects: | ||
| - | * [[projects: | ||
| + | * [[doc: | ||
| ====== Development ====== | ====== Development ====== | ||
| ===== PC/Host Environment ===== | ===== PC/Host Environment ===== | ||
| - | * [[projects:crazyflie:pc_utils:pylib|Crazyflie Python Library]]: Documentation for the Python library used to communicate with the Crazyflie | + | * [[doc:crazyflie:api:python: |
| + | ===== Android Environment ===== | ||
| + | * [[doc: | ||
| ===== Firmware ===== | ===== Firmware ===== | ||
| Line 38: | Line 44: | ||
| ===== Electronics ===== | ===== Electronics ===== | ||
| - | * [[projects: | + | * [[misc: |
| - | ===== Expansion boards ===== | + | |
| - | * [[projects: | + | |
