User Tools
Site Tools
projects:crazyflie:index
Differences
Link to this comparison view
Next revision
Previous revision
projects:crazyflie:index [2016-03-29 16:36]
bjorn [Using the Crazyflie]
projects:crazyflie:index [2021-06-24 16:49] (current)
Line 1: Line 1:
-====== Crazyflie Nano Quadcopter ======+<WRAP center round important 60%>
 +</WRAP>
 +====== Crazyflie 1.0 ======
 The Crazyflie is a tiny quadcopter often referred to as a nano-quad, built using the PCB itself as the frame. Developed solely by open source tools and designed with development in mind. E.g. we choose 0603 components (resistors & caps) over 0402 to make it easier to replace components. The voltage regulators are adjustable which makes it possible to change the digital and analog supply voltages simply by changing a couple of resistors. The Crazyflie is a tiny quadcopter often referred to as a nano-quad, built using the PCB itself as the frame. Developed solely by open source tools and designed with development in mind. E.g. we choose 0603 components (resistors & caps) over 0402 to make it easier to replace components. The voltage regulators are adjustable which makes it possible to change the digital and analog supply voltages simply by changing a couple of resistors.
Line 28: Line 31:
   * [[doc:crazyflie:client:cfandroid:index|Android client user guide]]: Install instructions and user guide for the Crazyflie Android client   * [[doc:crazyflie:client:cfandroid:index|Android client user guide]]: Install instructions and user guide for the Crazyflie Android client
 ====== Development ====== ====== Development ======
-  * [[projects:crazyflie:wishlist| Wishlist and expansion ideas]]: Our and other peoples wishlists, project ideas and possible expansions
   * [[projects:contribution:index | How to contribute to the project]]   * [[projects:contribution:index | How to contribute to the project]]
projects/crazyflie/index.1459262197.txt.gz · Last modified: 2016-03-29 16:36 by bjorn
