User Tools
Site Tools
projects:crazyflie:index
Differences
Link to this comparison view
projects:crazyflie:index [2018-01-16 16:25]
bjorn [Development]
projects:crazyflie:index [2021-06-24 16:49] (current)
Line 1: Line 1:
 +</WRAP>
 ====== Crazyflie 1.0 ====== ====== Crazyflie 1.0 ======
 The Crazyflie is a tiny quadcopter often referred to as a nano-quad, built using the PCB itself as the frame. Developed solely by open source tools and designed with development in mind. E.g. we choose 0603 components (resistors & caps) over 0402 to make it easier to replace components. The voltage regulators are adjustable which makes it possible to change the digital and analog supply voltages simply by changing a couple of resistors. The Crazyflie is a tiny quadcopter often referred to as a nano-quad, built using the PCB itself as the frame. Developed solely by open source tools and designed with development in mind. E.g. we choose 0603 components (resistors & caps) over 0402 to make it easier to replace components. The voltage regulators are adjustable which makes it possible to change the digital and analog supply voltages simply by changing a couple of resistors.
projects/crazyflie/index.1516116326.txt.gz · Last modified: 2018-01-16 16:25 by bjorn
