projects:crazyflie:mechanics:assembly [2013-06-01 23:16] foosel [What do you need to do] |
projects:crazyflie:mechanics:assembly [2015-07-15 16:31] 127.0.0.1 external edit |
Line 32: | Line 32: | ||
- | 2. Twist the two motor wires together so they are easier to handle | + | 2. Twist the two motor wires together so they are easier to handle |
Line 68: | Line 68: | ||
- | 9. Attach the propellers (see drawings below for mapping). You got two packs of them with your kit, containing 5 each of clockwise and counter-clockwise ones. Your clockwise propellers may be labeled with an " | + | 9. Attach the propellers (see drawings below for mapping). |
Line 86: | Line 86: | ||
Assembly video using new motor mounts | Assembly video using new motor mounts | ||
{{youtube> | {{youtube> | ||
- | Old assembly video using 3D printed motor mounts | ||
- | {{youtube> | ||
