                    projects:crazyflie:pc_utils:debugdriver [2012-12-30 01:12] macke created  |
                    projects:crazyflie:pc_utils:debugdriver [2021-06-24 16:52] (current) kimberly  |
| ====== Client-side debugging ====== | ====== Client-side debugging ====== | ||
| The client-side debugging feature is used mainly to debug the UI on the client side without having a Crazyflie connected. | The client-side debugging feature is used mainly to debug the UI on the client side without having a Crazyflie connected. | ||
| To accomplish this there' | To accomplish this there' | ||
| + | To enable the DebugDriver interface you will have to edit the configuration file (config.json) and set the '' | ||
| ====== Debugging during connection ====== | ====== Debugging during connection ====== | ||
