projects:crazyflie:pc_utils:dev_guide [2013-03-14 22:53] macke |
projects:crazyflie:pc_utils:dev_guide [2021-06-24 16:52] (current) kimberly |
| - | ====== | + | <WRAP center round important 60%> |
| - | ===== Fedora | + | This page has deprecated and will be archived. Please go to [[https:// |
| - | Tested | + | </ |
| + | ===== Installing | ||
| + | This guide will help you get up and started | ||
| + | ==== Getting the source code ==== | ||
| + | The sources for the Crazyflie Python client are hosted | ||
| + | After forking the repository, you have a complete copy of the code and all its history on GitHub. You can clone this repository using Git: | ||
| - | sudo yum install qt-devel | + | git clone [[https:// |
| - | ====== Coding standard | + | Git will make a subdirectory in the directory that you execute the command in and clone the repository there. |
| + | ==== Installing the sources in your home profile ==== | ||
| + | When developing with the Crazyflie Python client, it is helpful to develop, run and test the code in a user profile rather than installing it with root permissions system-wide. This way you can test changes without needing to reinstall into root-owned directories. The best way to do this is to simply execute the Python client from its path where you're developing it. | ||
| + | However, you might want to install the client like a " | ||
| + | python setup.py install --user | ||
| + | This installs the sources into your user profile (e.g. in ~/.local). If you want to be able to run the Python client, you can either execute it straight from the sources, or from the executable installed in your profile (e.g. ~/ | ||
| + | export PATH=$PATH: | ||
| + | If you don't use the setup script, but want to be able to add the repository' | ||
| + | ==== Testing changes ==== | ||
| + | Now that everything' | ||
| + | ==== Contributing your changed code ==== | ||
| + | If you've tested your changes and everything' | ||
| + | git push | ||
| + | The buttons on the top left left you compare the code you've written with Bitcraze' | ||
| + | ===== Coding standard ===== | ||
| Currently this code is pretty messy but it's being modified to follow [[http:// | Currently this code is pretty messy but it's being modified to follow [[http:// | ||
