projects:crazyflie:pc_utils:index [2013-05-24 14:12] macke |
projects:crazyflie:pc_utils:index [2021-06-24 16:52] (current) kimberly |
| ====== Crazyflie PC utilities ====== | ====== Crazyflie PC utilities ====== | ||
| The Crazyflie PC utilities are developed using Python 2.7. The Crazyflie library is used from the command line tools as well as a graphical user interface. For install instructions of PC side software please see [[projects: | The Crazyflie PC utilities are developed using Python 2.7. The Crazyflie library is used from the command line tools as well as a graphical user interface. For install instructions of PC side software please see [[projects: | ||
| Line 7: | Line 10: | ||
| ====== List of applications ====== | ====== List of applications ====== | ||
| ===== Crazyflie control UI ===== | ===== Crazyflie control UI ===== | ||
| - | The Crazyflie control UI is used to pilot the Crazyflie using a graphical user interface. A userguide for the GUI application can be found [[projects:crazyflie:pc_utils:qt_ui|here]]. Normally this is started from the start menu (or similar) if you have used an installer. There' | + | The Crazyflie control UI is used to pilot the Crazyflie using a graphical user interface. A userguide for the GUI application can be found [[doc:crazyflie:client:pycfclient: |
| Line 21: | Line 24: | ||
| ===== Crazyflie headless client ===== | ===== Crazyflie headless client ===== | ||
| - | The Crazyflie headless client is intended to be run on the Raspberry Pi (see [[projects: | + | The Crazyflie headless client is intended to be run on the Raspberry Pi (see [[misc: |
| - | **Note:** These files are still on a feature branch and not merged to the default one (dev-headless). | + | |
