projects:crazyflie:pc_utils:inputdevices [2013-12-03 10:43] macke [Linux using Bluetooth] |
projects:crazyflie:pc_utils:inputdevices [2017-05-22 11:42] arnaud [Linux using USB] |
====== Input-devices for the Crazyflie client ====== | ====== Input-devices for the Crazyflie client ====== | ||
- | The Crazyflie graphical control client needs an input-device (joystick) with a minimum of 4 analogue | + | The Crazyflie graphical control client needs an input-device (joystick) with a minimum of 4 analogue |
===== Limitations ===== | ===== Limitations ===== | ||
Line 19: | Line 19: | ||
Below is a list of controllers and the status for different OSs. The list is far from complete so if you have more info please edit or drop us an email. | Below is a list of controllers and the status for different OSs. The list is far from complete so if you have more info please edit or drop us an email. | ||
- | ^ **Controller** | + | ^ **Controller** |
- | | Playstation 3 (or copy) | Works | [[projects: | + | | Playstation 3 (or copy) | Works | [[projects: |
- | | Xbox 360 (or copy) | [[projects: | + | | Xbox 360 (or copy) | [[projects: |
====== Playstation 3 controller ====== | ====== Playstation 3 controller ====== | ||
Line 43: | Line 43: | ||
===== Linux using USB ===== | ===== Linux using USB ===== | ||
- | If you are having problems getting this to work (or you are using the wireless version) then the userspace driver '' | + | <WRAP center round tip 80%> |
+ | **INFO** | ||
+ | If you are having problems getting this to work the userspace driver '' | ||
sudo apt-get install xboxdrv | sudo apt-get install xboxdrv |
