projects:crazyflie:pc_utils:inputdevices [2013-12-03 10:43] macke [Linux using Bluetooth] |
projects:crazyflie:pc_utils:inputdevices [2020-05-12 14:29] (current) kimberly |
| ====== Input-devices for the Crazyflie client ====== | ====== Input-devices for the Crazyflie client ====== | ||
| - | The Crazyflie graphical control client needs an input-device (joystick) with a minimum of 4 analogue | + | The Crazyflie graphical control client needs an input-device (joystick) with a minimum of 4 analogue |
| ===== Limitations ===== | ===== Limitations ===== | ||
| Line 19: | Line 23: | ||
| Below is a list of controllers and the status for different OSs. The list is far from complete so if you have more info please edit or drop us an email. | Below is a list of controllers and the status for different OSs. The list is far from complete so if you have more info please edit or drop us an email. | ||
| - | ^ **Controller** | + | ^ **Controller** |
| - | | Playstation 3 (or copy) | Works | [[projects: | + | | Playstation 3 (or copy) | Works | [[projects: |
| - | | Xbox 360 (or copy) | [[projects: | + | | Xbox 360 (or copy) | [[projects: |
| ====== Playstation 3 controller ====== | ====== Playstation 3 controller ====== | ||
| Line 43: | Line 47: | ||
| ===== Linux using USB ===== | ===== Linux using USB ===== | ||
| - | If you are having problems getting this to work (or you are using the wireless version) then the userspace driver '' | + | <WRAP center round tip 80%> |
| + | **INFO** | ||
| + | All modern Linux distribution now have a kernel driver for the x-box gamepad. Thus it is unlikely the //xboxdrv// user-space driver is needed. | ||
| + | If you are having problems getting this to work the userspace driver '' | ||
| sudo apt-get install xboxdrv | sudo apt-get install xboxdrv | ||
