projects:crazyflie:pc_utils:inputdevices [2014-08-31 11:26] macke [Input device overview] |
projects:crazyflie:pc_utils:inputdevices [2020-05-12 14:29] (current) kimberly |
| ====== Input-devices for the Crazyflie client ====== | ====== Input-devices for the Crazyflie client ====== | ||
| - | The Crazyflie graphical control client needs an input-device (joystick) with a minimum of 4 analogue | + | The Crazyflie graphical control client needs an input-device (joystick) with a minimum of 4 analogue |
| ===== Limitations ===== | ===== Limitations ===== | ||
| Line 43: | Line 47: | ||
| ===== Linux using USB ===== | ===== Linux using USB ===== | ||
| - | If you are having problems getting this to work (or you are using the wireless version) then the userspace driver '' | + | <WRAP center round tip 80%> |
| + | **INFO** | ||
| + | All modern Linux distribution now have a kernel driver for the x-box gamepad. Thus it is unlikely the //xboxdrv// user-space driver is needed. | ||
| + | If you are having problems getting this to work the userspace driver '' | ||
| sudo apt-get install xboxdrv | sudo apt-get install xboxdrv | ||
