projects:crazyflie:pc_utils:inputdevices [2014-10-10 21:30] chad [Input-devices for the Crazyflie client] Spelling for axis - plural |
projects:crazyflie:pc_utils:inputdevices [2019-09-05 15:33] kimberly |
+ | https:// | ||
====== Input-devices for the Crazyflie client ====== | ====== Input-devices for the Crazyflie client ====== | ||
The Crazyflie graphical control client needs an input-device (joystick) with a minimum of 4 analogue axes to be able to pilot the Crazyflie. The Playstation 3 controller is supported out of the box but the application supports creating new configurations that uses other controllers. This page details what controllers are supported out of the box, how to create a new configurations and how to debug problems. | The Crazyflie graphical control client needs an input-device (joystick) with a minimum of 4 analogue axes to be able to pilot the Crazyflie. The Playstation 3 controller is supported out of the box but the application supports creating new configurations that uses other controllers. This page details what controllers are supported out of the box, how to create a new configurations and how to debug problems. | ||
Line 43: | Line 53: | ||
===== Linux using USB ===== | ===== Linux using USB ===== | ||
- | If you are having problems getting this to work (or you are using the wireless version) then the userspace driver '' | + | <WRAP center round tip 80%> |
+ | **INFO** | ||
+ | If you are having problems getting this to work the userspace driver '' | ||
sudo apt-get install xboxdrv | sudo apt-get install xboxdrv |
