projects:crazyflie:pc_utils:install [2013-05-09 15:12] skube [Installing on Mac OSX] |
projects:crazyflie:pc_utils:install [2015-09-10 11:00] (current) macke |
- | ====== Crazyflie PC client installation ====== | + | In the interest |
- | The Crazyflie PC utilities are developed using Python 2.7. The Crazyflie library is used from the command line tools as well as a graphical user interface. On Windows an installer permits to run the client without having to install any dependencies, | + | |
- | ===== Installing on windows ===== | + | |
- | Download and run the installer from the [[projects: | + | |
- | To install the Crazyradio dongle follow the instruction [[projects: | + | |
- | ===== Installing on Linux ===== | + | |
- | The following has to be installed for the PC utilities to work: | + | |
- | * Python 2.7 | + | |
- | * pyGame | + | |
- | * PyUSB (0.X or 1.X) | + | |
- | * libusb | + | |
- | For the graphical userinterface to work the following is also needed: | + | |
- | * Python bindings for Qt4 | + | |
- | ==== Fedora ==== | + | |
- | The following has been tested on Fedora 16 to 18. Note that this will pull in a lot of dependencies. | + | |
- | sudo yum install pygame pyusb PyQt4 | + | |
- | ==== Ubuntu ==== | + | |
- | The following has been tested on Ubuntu 10.04/ | + | |
- | sudo apt-get install python2.7 python-usb python-pygame python-qt4 | + | |
- | ==== Fix udev premissions on Linux ==== | + | |
- | In order to fix the permissions so it's possible to use the USB Radio without being root do the following steps. | + | |
- | sudo groupadd plugdev | + | |
- | sudo usermod -a -G plugdev < | + | |
- | Create a file named / | + | |
- | SUBSYSTEM==" | + | |
- | Restart the computer and you are now able to access the USB radio dongle without being root. | + | |
- | ==== Running the client ==== | + | |
- | Decompress the source code in a folder, open a console and type: | + | |
- | cd < | + | |
- | python2 bin/ | + | |
- | ===== Running source code on Windows ===== | + | |
- | This procedure is required if you want to develop with the Crazyflie client on Windows. If you just want to run and fly the Carzyflie follow the instruction to install | + | |
- | ==== Windows XP ==== | + | |
- | The following has to be downloaded/ | + | |
- | * [[http:// | + | |
- | ==== Windows Vista/7 32/ | + | |
- | Even if you have a 64-bit install you should download the 32-bit versions of the libraries since this makes everything easier. | + | |
- | ===== Installing on Mac OSX ===== | + | |
- | **IMPORTANT NOTE**: The following will use homebrew and it's own python distribution. If you have a lot of other 3rd party python stuff already running on your system they might or might not affected of this. | + | |
- | - Open a terminal and install [[http:// | + | |
- | - Now make sure that the new python version is used for non-homebrew applications. To do this we need to prepend this installation to our PYTHONPATH: < | + | |
- | echo ' | + | |
- | source ~/ | + | |
- | - Install SDL for Python:< | + | |
- | - Install PyQT:< | + | |
- | - Now use pip to install pyGame:< | + | |
- | - Install pyusb:< | + | |
- | You now have all the dependencies needed to run the client. Download and extract the client and then start it by running the following in a terminal:< | + |
