projects:crazyflie:pc_utils:install [2013-05-11 20:47] skube [Fix udev premissions on Linux] |
projects:crazyflie:pc_utils:install [2015-09-10 11:00] (current) macke |
| - | ====== Crazyflie PC client installation ====== | + | In the interest |
| - | The Crazyflie PC utilities are developed using Python 2.7. The Crazyflie library is used from the command line tools as well as a graphical user interface. On Windows an installer permits to run the client without having to install any dependencies, | + | |
| - | ===== Installing on windows ===== | + | |
| - | Download and run the installer from the [[projects: | + | |
| - | To install the Crazyradio dongle follow the instruction [[projects: | + | |
| - | ===== Installing on Linux ===== | + | |
| - | The following has to be installed for the PC utilities to work: | + | |
| - | * Python 2.7 | + | |
| - | * pyGame | + | |
| - | * PyUSB (0.X or 1.X) | + | |
| - | * libusb | + | |
| - | For the graphical userinterface to work the following is also needed: | + | |
| - | * Python bindings for Qt4 | + | |
| - | ==== Fedora ==== | + | |
| - | The following has been tested on Fedora 16 to 18. Note that this will pull in a lot of dependencies. | + | |
| - | sudo yum install pygame pyusb PyQt4 | + | |
| - | ==== Ubuntu ==== | + | |
| - | The following has been tested on Ubuntu 10.04/ | + | |
| - | sudo apt-get install python2.7 python-usb python-pygame python-qt4 | + | |
| - | ==== Fix udev premissions on Linux ==== | + | |
| - | In order to fix the permissions so it's possible to use the USB Radio without being root do the following steps. | + | |
| - | Note: If using a fresh Debian | + | |
| - | apt-get install sudo</ | + | |
| - | Now, with sudo installed, you should be able to do the following commands | + | |
| - | sudo groupadd plugdev | + | |
| - | sudo usermod -a -G plugdev < | + | |
| - | Create a file named / | + | |
| - | SUBSYSTEM==" | + | |
| - | Restart the computer and you are now able to access the USB radio dongle without being root. | + | |
| - | ==== Running the client ==== | + | |
| - | Decompress the source code in a folder, open a console and type: | + | |
| - | cd < | + | |
| - | python2 bin/ | + | |
| - | ===== Running source code on Windows ===== | + | |
| - | This procedure is required if you want to develop with the Crazyflie client on Windows. If you just want to run and fly the Carzyflie follow the instruction to install the client above. | + | |
| - | ==== Windows XP ==== | + | |
| - | The following has to be downloaded/ | + | |
| - | * [[http:// | + | |
| - | ==== Windows Vista/7 32/ | + | |
| - | Even if you have a 64-bit install you should download the 32-bit versions of the libraries since this makes everything easier. | + | |
| - | ===== Installing on Mac OSX ===== | + | |
| - | **IMPORTANT NOTE**: The following will use homebrew and it's own python distribution. If you have a lot of other 3rd party python stuff already running on your system they might or might not affected of this. | + | |
| - | - Open a terminal and install [[http:// | + | |
| - | - Now make sure that the new python version is used for non-homebrew applications. To do this we need to prepend this installation to our PYTHONPATH: < | + | |
| - | echo ' | + | |
| - | source ~/ | + | |
| - | - Install SDL for Python:< | + | |
| - | - Install PyQT:< | + | |
| - | - Install Mercurial: < | + | |
| - | - Now use pip to install pyGame:< | + | |
| - | - Install pyusb:< | + | |
| - | You now have all the dependencies needed to run the client. [[projects: | + | |
