projects:crazyflie:pc_utils:pylib [2013-02-18 22:17] macke |
projects:crazyflie:pc_utils:pylib [2021-06-24 16:58] (current) kimberly |
| - | ====== The Crazyflie Python API ====== | + | <WRAP center round important 60%> |
| - | In order to easily use and control the Crazyflie there' | + | This page has deprecated |
| - | + | </WRAP> | |
| - | If you are interested in more details look in the PyDoc in the code or: | + | This topic has been moved [[doc:crazyflie:api:python:index|here]]. |
| - | * Communication protocol for [[projects: | + | |
| - | * Firmware implementation of the [[projects: | + | |
| - | ===== Structure of the library ===== | + | |
| - | **TODO** | + | |
| - | ===== Connection- and link-callbacks ===== | + | |
| - | The library uses callbacks for asynchronous events such as when the connection is dropped or when new logging data arrives. Here's a list of linkstatus callbacks: | + | |
| - | To register for callbacks the following is used: | + | |
| - | <code python> | + | |
| - | crazyflie = Crazyflie() | + | |
| - | crazyflie.linkQuality.addCallback(linkQualityCallback) | + | |
| - | There are more callbacks than this available in the Crazyflie but these are the ones most useful. | + | |
| - | ===== Uniform Resource Identifier (URI) ===== | + | |
| - | All communication links are identified using an URI build up of the following: %%InterfaceType:// | + | |
| - | Currently only //radio// and //debug// interfaces are used but there' | + | |
| - | * %%radio:// | + | |
| - | * %%debug:// | + | |
| - | ===== Variable and parameter names ===== | + | |
| - | All names of parameters and loggable variables use the same structure: // | + | |
| - | There' | + | |
| - | * stabalizer.roll | + | |
| - | * system.battery | + | |
| - | ===== Finding a Crazyflie and connecting ===== | + | |
| - | The first thing to do is to find a Crazyflie quadcopter that we can connect to. This is done by queuing the library that will scan all the available interfaces (currently the debug and radio interface). | + | |
| - | cflib.crtp.initDrivers() | + | |
| - | available = cflib.crtp.scanInterfaces() | + | |
| - | for a in available: | + | |
| - | print " | + | |
| - | Opening and closing a communication link is doing by using the Crazyflie object: | + | |
| - | crazyflie.openLink(" | + | |
| - | # Do stuff | + | |
| - | crazyflie.closeLink() | + | |
| - | ===== Sending control commands ===== | + | |
| - | Currently all the communication is either parameters, logging or control commands. The special case of control commands is minimize latency since it's a faster way than using parameters. | + | |
| - | To send a new control set-point use the following: | + | |
| - | roll = 0.0 | + | |
| - | pitch = 0.0 | + | |
| - | yawrate = 0 | + | |
| - | thrust | + | |
| - | crazyflie.commander.sendControlSetpoint(roll, | + | |
| - | </code> | + | |
| - | ===== Parameters ===== | + | |
| - | The parameter framework is used to read and set parameters. This functionality should be used when: | + | |
| - | * The parameter is not changed by the Crazyflie but by the client | + | |
| - | * The parameter is not read periodically | + | |
| - | If this is not the case then the logging framework should be used instead. | + | |
| - | To set a parameter you have to the connected to the Crazyflie. A parameter is set using: | + | |
| - | parameterName = " | + | |
| - | parameterValue = 3 | + | |
| - | crazyflie.param.setParamValue(parameterName, | + | |
| - | </code> | + | |
| - | The parameter reading is done using callbacks. When the connection is established to the Crazyflie all the parameters are read. When a parameter is updated from the client (using the code above) the parameter will be requested again by the library and this will trigger the callbacks. Parameter callbacks can be added at any time (you don't have to be connected to a Crazyflie). | + | |
| - | crazyflie.param.addParamUpdateCallback(" | + | |
| - | def paramUpdateCallback(name, | + | |
| - | print "%s has value %d" % (name, value) | + | |
| - | A callback can also be removed using: | + | |
| - | ===== Logging ===== | + | |
| - | The logging framework is used to enable the " | + | |
| - | * The variable is changed by the Crazyflie and not by the client | + | |
| - | * The variable is updated at high rate and you want to read the value periodically | + | |
| - | If this is not the case then the parameter framework should be used instead. | + | |
| - | To create a logging configuration the following can be used: | + | |
| - | periodInMilliSeconds = 10 | + | |
| - | logconf = LogConfig(" | + | |
| - | logconf.addVariable(LogVariable(" | + | |
| - | The datatype should match what has been configured in the Crazyflie firmware. The valid datatypes are: | + | |
| - | * float | + | |
| - | * uint8_t and int8_t | + | |
| - | * uint16_t and int16_t | + | |
| - | * uint32_t and int32_t | + | |
| - | * FP16 (this is a fixed point version of floating point) | + | |
| - | The logging cannot be started until your are connected to a Crazyflie: | + | |
| - | # Callback called when the connection is established to the Crazyflie | + | |
| - | def connected(linkURI): | + | |
| - | logpacket = crazyflie.log.newLogPacket(logconf) | + | |
| - | if (logpacket != None): | + | |
| - | logpacket.dataReceived.addCallback(dataCallback) | + | |
| - | logpacket.startLogging() | + | |
| - | else: | + | |
| - | print "One or more of the variables in the configuration was not found in log TOC. No logging will be possible." | + | |
| - | def dataCallback(data): | + | |
| - | # Print all the keys and values for them | + | |
| - | for k in data.keys(): | + | |
| - | print "Key: %s=%s" % (k, str(data[k])) | + | |
| - | ====== Logging and parameter examples ====== | + | |
| - | Below are the two examples described in the video <insert link to video here when done> that shows the parameter and logging framework. They have been re-written to fit outside the QT context so they do not match the video 1:1 but they show the same concept. | + | |
| - | Remember that if you use the callbacks for parameters and logging together with QT and the callbacks manipulate objects in the UI then they have to be wrapped using signals. Otherwise you will en up with timing issues that will (at some point) crash the application since UI objects should only be updated but the same thread that draws the objects. | + | |
| - | ===== Adding a parameter ===== | + | |
| - | In this example we will add a parameter that will be used to " | + | |
| - | First of all we need to add the parameter to the firmware, this is done by using the macros PARAM_GROUP_START, | + | |
| - | <code c> | + | |
| - | #include " | + | |
| - | bool ledFreeze = false; | + | |
| - | PARAM_GROUP_START(led) | + | |
| - | PARAM_ADD(PARAM_UINT8, | + | |
| - | PARAM_GROUP_STOP(led) | + | |
| - | This will add a parameter in the TOC named // | + | |
| - | Now we should use this parameter on the client side. This can either be done by reading or writing the parameter. First we add the code to write the parameter: | + | |
| - | # crazyflie is an instance of the Crazyflie class that has been instantiated and connected | + | |
| - | crazyflie.param.setParamValue(" | + | |
| - | The parameter-framework relies on the fact that the parameters are changed from the client or that the client polls the value of parameters. If you are interested in logging changes that the Crazyflie does itself then the logging-framework is better. If you are interested in reading a parameter this should be done using a callback that will be called from the framework when the value for the parameter is updated. This happens in two cases: | + | |
| - | * When the Crazyflie has connected values for all the parameters in the TOC are fetched | + | |
| - | * When the client changes a value for a parameter the new value will be sent back from the Crazyflie | + | |
| - | To register for a callback and to implement the callback the following is used: | + | |
| - | print "%s has value %s" % (name, value) # This will in our example print: led.freeze has value True | + | |
| - | ===== Adding loggable variables ===== | + | |
| - | In this example we will add logging for the raw gyro values read from the sensor. | + | |
| - | First of all we add the variables to the logging TOC by using the macros LOG_GROUP_START, | + | |
| - | // The raw gyro values are stored in the gyro struct | + | |
| - | LOG_GROUP_START(gyro) | + | |
| - | LOG_ADD(LOG_FLOAT, | + | |
| - | LOG_GROUP_STOP(gyro) | + | |
| - | This will add the variables //gyro.x//, //gyro.y// and //gyro.z// to the logging TOC as floats. | + | |
| - | On the client side we now add the log configuration, | + | |
| - | gyroconf = LogConfig(" | + | |
| - | gyroconf.addVariable(LogVariable(" | + | |
| - | gyrolog = crazyflie.log.newLogPacket(gyroconf) | + | |
| - | if (gyrolog != None): | + | |
| - | gyrolog.dataReceived.addCallback(gyroData) | + | |
| - | gyrolog.startLogging() | + | |
| - | else: | + | |
| - | print " | + | |
| - | def gyroData(data): | + | |
| - | print " | + | |
