                    projects:crazyflie:pc_utils:pylib [2014-02-12 13:37] tobias [Examples]  |
                    projects:crazyflie:pc_utils:pylib [2021-06-24 16:58] (current) kimberly  |
| - | ====== The Crazyflie Python API ====== | + | <WRAP center round important 60%> |
| - | In order to easily use and control the Crazyflie there' | + | This page has deprecated  |
| - | + | </WRAP> | |
| - | If you are interested in more details look in the PyDoc in the code or: | + | This topic has been moved [[doc:crazyflie:api:python:index|here]]. |
| - |   * Communication protocol for [[projects: | + | |
| - |   * Firmware implementation of the [[projects: | + | |
| - | ====== Structure of the library ====== | + | |
| - | The library is asynchronous and based on callbacks for events. Functions like '' | + | |
| - | ===== Uniform Resource Identifier (URI) ===== | + | |
| - | All communication links are identified using an URI build up of the following:  | + | |
| - | Currently only //radio// and //debug// interfaces are used but there' | + | |
| - |   * %%Radio interface, USB dongle number 0, radio channel 10 and radio speed 250 Kbit/s: radio:// | + | |
| - |   * %%Debug interface, id 0, channel 1: debug:// | + | |
| - | ===== Variables and logging ===== | + | |
| - | The library supports setting up logging configurations that are used for logging variables from the firmware. Each log configuration contains a number of variables that should be logged as well as a time period (in ms) of how often the data should be sent back to the host. Once the log configuration is added to the firmware the firmware will automatically send back the data at every period. These configurations are used in the following way: | + | |
| - | * Connect to the Crazyflie (log configurations needs a TOC to work) | + | |
| - | * Create a log configuration that contains a number of variables to log and a period at which they should be logged | + | |
| - | * Add the log configuration. This will also validate that the log configuration is sane (i.e uses a supported period and all variables are in the TOC) | + | |
| - | * After checking that the configuration is valid, set up callbacks for the data in your application and start the log configuration | + | |
| - | * Each time the firmware sends data back to the host the callback will the called with a time-stamp and the data | + | |
| - | There' | + | |
| - | * Each packet is limited to 32bytes, which means that the data that is logged and the packet that is sent to set it up cannot be larger than this. It limits the logging to about 14 variables, but this is dependent on what types they are | + | |
| - | * The minimum period of a for a log configuration is multiples of 10ms | + | |
| - | ===== Parameters ===== | + | |
| - | The library supports reading and writing parameters at run-time to the firmware. This is intended to be used for data that is not continuously being changed by the firmware, like setting regulation parameters and reading out if the power-on self-tests passed. Parameters should only change in the firmware when being set from the host or during start-up. The library doesn' | + | |
| - | * Register parameter updated callbacks at any time in your application | + | |
| - | * Connect to your Crazyflie (this will download the parameter TOC) | + | |
| - | * Request updates for all the parameters | + | |
| - | * The library will call all the callbacks registered | + | |
| - | * The host can now write parameters that will be forwarded to the firmware | + | |
| - | * For each write all the callbacks registered for this parameter will be called back | + | |
| - | ===== Variable and parameter names ===== | + | |
| - | All names of parameters and log variables use the same structure: '' | + | |
| - | The group should be used to bundle together logical groups, like everything that has to do with the stabilizer should be in the group '' | + | |
| - | There' | + | |
| - | * stabilizer.roll | + | |
| - | * stabilizer.pitch | + | |
| - | * pm.vbat | + | |
| - | * imu_tests.MPU6050 | + | |
| - | * pid_attitide.pitch_kd | + | |
| - | ====== Utilities ====== | + | |
| - | ===== Callbacks ===== | + | |
| - | All callbacks are handled using the '' | + | |
| - | <code python> | + | |
| - | remove_callback(cb) | + | |
| - | call(*args) | + | |
| - | ===== Debug driver ===== | + | |
| - | The library contains a special link driver, named '' | + | |
| - | * Connecting a download param and log TOCs | + | |
| - | * Setting up log configurations and sending back fake data | + | |
| - | * Setting and reading parameters | + | |
| - | * Bootloading | + | |
| - | There are a number of different URIs that will be returned from the driver. These will have different functions, like always returning a random TOC CRC to always trigger TOC downloading or failing during connect. The driver also has support for sending back data with random delays to trigger random re-sending by the library. | + | |
| - | ====== Initiating the link drivers ====== | + | |
| - | Before the library can be used the link drivers have to he initialized. This will search for available drivers  | + | |
| - | init_drivers(enable_debug_driver=False) | + | |
| - | ====== Connection- and link-callbacks ====== | + | |
| - | Operations on the link and connection will return directly and will call the following callbacks when events occur: | + | |
| - | # Called on disconnect, no matter the reason | + | |
| - | disconnected = Caller() | + | |
| - | # Called on unintentional disconnect only | + | |
| - | connection_lost = Caller() | + | |
| - | # Called when the first packet in a new link is received | + | |
| - | link_established = Caller() | + | |
| - | # Called when the user requests a connection | + | |
| - | connection_requested = Caller() | + | |
| - | # Called when the link is established and the TOCs (that are not cached) | + | |
| - | # have been downloaded | + | |
| - | connected = Caller() | + | |
| - | # Called if establishing of the link fails (i.e times out) | + | |
| - | connection_failed = Caller() | + | |
| - | # Called for every packet received | + | |
| - | packet_received = Caller() | + | |
| - | # Called for every packet sent | + | |
| - | packet_sent = Caller() | + | |
| - | # Called when the link driver updates the link quality measurement | + | |
| - | link_quality_updated = Caller() | + | |
| - | To register for callbacks the following is used: | + | |
| - | crazyflie = Crazyflie() | + | |
| - | crazyflie.connected.add_callback(crazyflie_connected) | + | |
| - | ====== Finding a Crazyflie and connecting ====== | + | |
| - | The first thing to do is to find a Crazyflie quadcopter that we can connect to. This is done by queuing the library that will scan all the available interfaces (currently the debug and radio interface). | + | |
| - | cflib.crtp.init_drivers() | + | |
| - | available = cflib.crtp.scan_interfaces() | + | |
| - |     for i in available: | + | |
| - |         print " | + | |
| - | Opening and closing a communication link is doing by using the Crazyflie object: | + | |
| - |     crazyflie.open_link(" | + | |
| - | Then you can use the following to close the link again: | + | |
| - | crazyflie.close_link() | + | |
| - | ====== Sending control commands ====== | + | |
| - | The control commands are not implemented as parameters, instead they have a special API. | + | |
| - |     send_setpoint(roll, | + | |
| - |         Send a new control set-point for roll/pitch/ | + | |
| - |         The arguments roll/ | + | |
| - | be sent to the copter | + | |
| - | To send a new control set-point use the following: | + | |
| - | roll = 0.0 | + | |
| - | pitch = 0.0 | + | |
| - | yawrate = 0 | + | |
| - |     thrust  | + | |
| - |     crazyflie.commander.send_setpoint(roll, | + | |
| - | </code> | + | |
| - | Thrust is an integer value ranging from 10001 (next to no power) to 60000 (full power). Sending a command makes it apply for 500 ms, after which the firmware will cut out the power. With this in mind, you need to try and maintain a thrust level, with a tick being sent at least once every 2 seconds. Ideally you should be sending one tick every 10 ms, for 100 commands a second.  | + | |
| - | ====== Parameters ====== | + | |
| - | The parameter framework is used to read and set parameters. This functionality should be used when: | + | |
| - | * The parameter is not changed by the Crazyflie but by the client | + | |
| - | * The parameter is not read periodically | + | |
| - | If this is not the case then the logging framework should be used instead. | + | |
| - | To set a parameter you have to the connected to the Crazyflie. A parameter is set using: | + | |
| - |     param_name = " | + | |
| - | param_value = 3 | + | |
| - | The parameter reading is done using callbacks. When a parameter is updated from the host (using the code above) the parameter will be read back by the library and this will trigger the callbacks. Parameter callbacks can be added at any time (you don't have to be connected to a Crazyflie). | + | |
| - |     add_update_callback(group, | + | |
| - | Add a callback for a specific parameter name or group. If not name is specified then | + | |
| - | all parameters in the group will trigger the callback. This callback will be executed | + | |
| - | when a new value is read from the Crazyflie. | + | |
| - | request_param_update(complete_name) | + | |
| - |     set_value(complete_name, | + | |
| - | Here's an example of how to use the calls. | + | |
| - |     crazyflie.param.add_update_callback(group=" | + | |
| - |     def param_updated_callback(name, | + | |
| - | print "%s has value %d" % (name, value) | + | |
| - | ====== Logging ====== | + | |
| - | The logging framework is used to enable the " | + | |
| - | * The variable is changed by the Crazyflie and not by the client | + | |
| - | * The variable is updated at high rate and you want to read the value periodically | + | |
| - | If this is not the case then the parameter framework should be used instead. | + | |
| - | The API to create and get information from LogConfig: | + | |
| - | # Called when new logging data arrives | + | |
| - | data_received_cb = Caller() | + | |
| - |     # Called when there' | + | |
| - | error_cb = Caller() | + | |
| - | # Called when the log configuration is confirmed to be started | + | |
| - | started_cb = Caller() | + | |
| - | # Called when the log configuration is confirmed to be added | + | |
| - | added_cb = Caller() | + | |
| - |     add_variable(name, | + | |
| - | name - Complete name of the variable in the form group.name | + | |
| - | fetch_as - String representation of the type the variable should be | + | |
| - | If no fetch_as type is supplied, then the stored as type will be used | + | |
| - | (i.e the type of the fetched variable is the same as it's stored in the | + | |
| - |         Crazyflie).""" | + | |
| - | start() | + | |
| - | stop() | + | |
| - | delete() | + | |
| - | The API for the log in the Crazyflie: | + | |
| - | add_config(logconf) | + | |
| - | When doing this the contents of the log configuration will be validated | + | |
| - | and listeners for new log configurations will be notified. When | + | |
| - | validating the configuration the variables are checked against the TOC | + | |
| - | to see that they actually exist. If they don't then the configuration | + | |
| - | cannot be used. Since a valid TOC is required, a Crazyflie has to be | + | |
| - |         connected when calling this method, otherwise it will fail.""" | + | |
| - | To create a logging configuration the following can be used: | + | |
| - |     logconf = LogConfig(name=" | + | |
| - |     logconf.add_variable(" | + | |
| - | The datatype should match what has been configured in the Crazyflie firmware. The valid datatypes are: | + | |
| - | * float | + | |
| - | * uint8_t and int8_t | + | |
| - | * uint16_t and int16_t | + | |
| - | * uint32_t and int32_t | + | |
| - | * FP16 (this is a fixed point version of floating point) | + | |
| - | The logging cannot be started until your are connected to a Crazyflie: | + | |
| - | # Callback called when the connection is established to the Crazyflie | + | |
| - |     def connected(link_uri): | + | |
| - | crazyflie.log.add_config(logconf) | + | |
| - |         if logconf.valid: | + | |
| - | logconf.data_received_cb.add_callback(data_received_callback) | + | |
| - | logconf.error_cb.add_callback(logging_error) | + | |
| - | logconf.start() | + | |
| - | else: | + | |
| - |             print "One or more of the variables in the configuration was not found in log TOC. No logging will be possible." | + | |
| - |     def data_received_callback(timestamp, | + | |
| - | print "[%d][%s]: %s" % (timestamp, logconf.name, data) | + | |
| - |     def logging_error(logconf, | + | |
| - | print "Error when logging %s" % logconf.name | + | |
| - | ====== Examples ====== | + | |
| - | The examples are now placed in the repository in the examples folder. | + | |
