projects:crazyflie:pc_utils:raspberrypi [2015-07-15 16:31] 127.0.0.1 external edit |
projects:crazyflie:pc_utils:raspberrypi [2021-06-24 16:47] (current) kimberly |
====== Modifying the Raspian Wheezy image ====== | ====== Modifying the Raspian Wheezy image ====== | ||
Here's a step by step guide to what we added. So if you don't want to use our image, you can get another one and set it up yourself. Most of this stuff is based of the contributed instructions from the [[misc: | Here's a step by step guide to what we added. So if you don't want to use our image, you can get another one and set it up yourself. Most of this stuff is based of the contributed instructions from the [[misc: | ||
Line 17: | Line 20: | ||
Now plug the SD-card into the Pi, attach all the cables and SSH to it. Log in user the username pi and the password raspberry and accept the fingerprint. | Now plug the SD-card into the Pi, attach all the cables and SSH to it. Log in user the username pi and the password raspberry and accept the fingerprint. | ||
+ | <WRAP center round tip> | ||
Lets install everything that we might need fro running the Crazyradio, controllers and the headless client. | Lets install everything that we might need fro running the Crazyradio, controllers and the headless client. |
