projects:crazyradio:programming [2013-05-14 09:19] arnaud [USB bootloader (command line instructions)] |
projects:crazyradio:programming [2019-09-05 14:53] kimberly |
- | ====== Radio programming ====== | + | <WRAP center round important 60%> |
- | The Radio dongle | + | [[ |
+ | https:// | ||
+ | ====== Crazyradio firmware upgrade ====== | ||
+ | **Please note: The current implementation of the bootloader/ | ||
+ | **Do not do development and flash you own firmware on the dongle | ||
+ | The Crazyradio contains a USB bootloader that gives the possibility to upgrade the firmware | ||
- | In Linux it might be required to launch the commands accessing the USB port as root (ie. with '' | ||
+ | Please note that you might have to exchange //python// with //python2// if you distro uses python3. | ||
First Crazyradio has to be rebooted in USB bootloader mode. To do so insert the dongle in the pc, open a terminal window and run the bootloader launcher: | First Crazyradio has to be rebooted in USB bootloader mode. To do so insert the dongle in the pc, open a terminal window and run the bootloader launcher: | ||
Line 15: | Line 30: | ||
- | After running this tool the Crazyradio dongle should have disappeared and a new device named '' | + | After running this tool the Crazyradio dongle should have disappeared and a new device named **nRF24LU1P-F32 BOOT LDR** should appear. |
To flash the firmware use the nrfbootload.py script: | To flash the firmware use the nrfbootload.py script: | ||
Line 21: | Line 36: | ||
> cd crazyradio-firmware | > cd crazyradio-firmware | ||
- | > python usbtools/ | + | > python usbtools/ |
Found nRF24LU1 bootloader version 18.0 | Found nRF24LU1 bootloader version 18.0 | ||
Flashing: | Flashing: | ||
- | Flashing | + | Flashing |
Flashing done! | Flashing done! | ||
Verifying: | Verifying: | ||
- | Reading cradio-0.51.bin... | + | Reading cradio-pa-0.53.bin... |
- | Reading | + | Reading |
Verification succeded! | Verification succeded! | ||
+ | ===== Step-by-step upgrade using the Bitcraze VM ===== | ||
+ | Below is a short guide with step-by-step instructions on how to upgrade the Crazyradio with the latest firmware using the [[projects: | ||
+ | * Start up the VM and download the latest firmware from [[https:// | ||
+ | * Open up a terminal | ||
+ | * Insert the Crazyradio and pass it to the VM | ||
+ | * Run the following commands: | ||
+ | > cd ~/ | ||
+ | > python usbtools/ | ||
+ | Launch bootloader . | ||
+ | Bootloader started | ||
+ | * Once the bootloader is started the Crazyradio dongle will dissapear ad a new device named **Nordic Semiconductor nRF24LU1P-F32 BOOT LDR** will appear. If you do not have a filter set up for the bootloader in the VM then script will say that it failed. This is ok. Pass the bootloader device into the VM and continue. | ||
+ | * Run the following command: | ||
+ | Flashing: | ||
+ | Flashing 5810 bytes... | ||
+ | Flashing done! | ||
+ | Verifying: | ||
+ | Reading cradio-pa-0.53.bin... | ||
+ | Reading 5810 bytes from the flash... | ||
+ | * If you see **Verification succeded** then unplug the dongle and re-insert it again. If you do not see this message, but instead some error. Do **NOT** unplug the dongle, try to reflash the firmware instead. | ||
+ | ===== Check your firmware version ===== | ||
+ | Run the following command: | ||
+ | > lsusb -d 1915:7777 -v | grep bcdDevice | ||
+ | This should return the version (e.g. " |
