projects:index [2013-01-16 09:34] macke |
projects:index [2015-07-15 16:31] 127.0.0.1 external edit |
+ | ====== Crazyflie 2.0 ====== | ||
+ | he Crazyflie 2.0 is a versatile flying development platform that only weights 27g and fits in the palm of your hand. It's advanced functionalities makes it ideal for developers and the Bluetooth LE capabilities makes it easy to fly from mobile devices. With it's small size and weight it's ideal for indoor use, but you can just as easily hover above your house as you can hover under your diningroom table. Designed as a solderless kit, the Crazyflie 2.0 is quickly assembled by attaching the motors to the circuitboard frame and it's ready to fly. | ||
+ | For more information about the project please see the [[projects: | ||
====== Crazyflie Micro Quadcopter Kit ====== | ====== Crazyflie Micro Quadcopter Kit ====== | ||
- | Ever wanted a development kit that flies? Well now you can! The Crazyflie is an open source nano quadcopter kit designed for flexible development and hacking. It's among the smallest in the world, weighing only 19 grams and measuring 9 cm motor to motor. | + | The Crazyflie is an open source nano quadcopter kit designed for flexible development and hacking. It's among the smallest in the world, weighing only 19 grams and measuring 9 cm motor to motor. |
The development platform is open source so schematics and firmware/ | The development platform is open source so schematics and firmware/ | ||
Line 10: | Line 16: | ||
This kit requires soldering skills and is not for beginners. Please see [[projects: | This kit requires soldering skills and is not for beginners. Please see [[projects: | ||
- | More details on this project can be found the [[projects: | + | More details on this project can be found on the [[projects: |
====== Crazyradio ====== | ====== Crazyradio ====== | ||
Line 21: | Line 27: | ||
A bootloader on the dongle enables firmware updates without using any external programmer. | A bootloader on the dongle enables firmware updates without using any external programmer. | ||
+ | ====== Bitcraze Virtual Machine ====== | ||
+ | In order for users and developers to get up and running as smoothly as possible we have made a virtual appliance available that can be imported into the virtual machine manager of your choice. This contains everything that is needed to fly the Crazyflie and to develop firmware for the Crazyflie/ | ||
+ | More details on the project can be found on the [[projects: |
