User Tools
Site Tools
projects:index
Differences
Link to this comparison view
Next revision
Previous revision
Last revision Both sides next revision
projects:index [2013-01-17 22:17]
macke
projects:index [2016-03-30 13:34]
bjorn
Line 1: Line 1:
-====== Crazyflie Micro Quadcopter Kit ====== +====== Crazyflie 2.0 ======
-Well now you canThe Crazyflie is an open source nano quadcopter kit designed for flexible development and hacking. It's among the smallest in the world, weighing only 19 grams and measuring 9 cm motor to motor.+he Crazyflie 2.0 is a versatile flying development platform that only weights 27g and fits in the palm of your hand. It's advanced functionalities makes it ideal for developers and the Bluetooth LE capabilities makes it easy to fly from mobile devices. With it's small size and weight it's ideal for indoor use, but you can just as easily hover above your house as you can hover under your diningroom table. Designed as a solderless kit, the Crazyflie 2.0 is quickly assembled by attaching the motors to the circuitboard frame and it's ready to fly.
 +For more information about the project please see the [[projects:crazyflie2:index|Crazyflie 2.0 project page]].
 +====== Crazyflie 1.0 ======
 +The Crazyflie is an open source nano quadcopter kit designed for flexible development and hacking. It's among the smallest in the world, weighing only 19 grams and measuring 9 cm motor to motor.
 The development platform is open source so schematics and firmware/host source code is available at the Bitcraze website as well as a Wiki with design information and details on how to set up the development environment and get started. It’s designed with development in mind and has an expansion header that enables developers to expand the platform as well as good software development support. Due to it’s small size it’s perfect for developing new software and can easily be flown inside. The development platform is open source so schematics and firmware/host source code is available at the Bitcraze website as well as a Wiki with design information and details on how to set up the development environment and get started. It’s designed with development in mind and has an expansion header that enables developers to expand the platform as well as good software development support. Due to it’s small size it’s perfect for developing new software and can easily be flown inside.
Line 10: Line 16:
 This kit requires soldering skills and is not for beginners. Please see [[projects:crazyflie:mechanics:assembly| assembly instructions and video]]. This kit requires soldering skills and is not for beginners. Please see [[projects:crazyflie:mechanics:assembly| assembly instructions and video]].
-More details on this project can be found the [[projects:crazyflie:index | Crazyflie project page]]+More details on this project can be found on the [[projects:crazyflie:index | Crazyflie project page]]
 ====== Crazyradio ====== ====== Crazyradio ======
Line 21: Line 27:
 A bootloader on the dongle enables firmware updates without using any external programmer. A bootloader on the dongle enables firmware updates without using any external programmer.
-More details on this project can be found the [[projects:crazyradio:index | Crazyradio project page]]+More details on this project can be found on the [[projects:crazyradio:index | Crazyradio project page]]
 +====== Bitcraze Virtual Machine ======
 +In order for users and developers to get up and running as smoothly as possible we have made a virtual appliance available that can be imported into the virtual machine manager of your choice. This contains everything that is needed to fly the Crazyflie and to develop firmware for the Crazyflie/Crazyradio as well as the PC side software.
 +More details on the project can be found on the [[projects:virtualmachine:index | Bitcraze VM project page]].
 +====== Bitcraze Docker Builder Image ======
 +An optional build environment, based on Docker. It provides the tools required to build Bitcraze projects without the need of installing anything else than Docker. Read more in [[projects:dockerbuilderimage:index | Bitcraze Docker Builder Image page]]
projects/index.txt · Last modified: 2021-06-24 16:34 by kimberly
