User Tools
Site Tools
projects:lps:index
Differences
Link to this comparison view
Next revision
Previous revision
projects:lps:index [2016-05-25 15:42]
projects:lps:index [2020-05-12 14:30] (current)
Line 1: Line 1:
-<WRAP center round info+<WRAP center round important 60%
-//**Early access**// +This page has deprecated and moved to the new documentation framework of the main Bitcraze website. Please go to [[https://www.bitcraze.io/documentation/system/]]
-Currently this product is in [[https://www.bitcraze.io/early-access/|early access]]. Basically we have finalized and tested the hardware but the software it still considered //beta//.+
 </WRAP> </WRAP>
-====== System overview ====== +====== Loco Positioning System ======
-The local positioning system is based on the [[http://www.decawave.com/|DecaWave]] DWM1000 module. The system consists of a number of anchors that's continuously pinged from the Crazyflie 2.0 deck that's based on the same module. The anchors are placed around the room at known positions (for now).+
-<WRAP group> +The loco positioning system (LPSproject is a set of hardware and software designed to implement a local positioning system (LPS)The hardware is based on the Decawave DW1000 chipFor more information about the system see the [[doc:lps:index|Loco positioning system documentation]]
-<WRAP half column> +
-Our testsystem uses the following components: +
-  * 6 anchors (with power cablesusing [[https://github.com/bitcraze/bitcraze-mechanics/blob/master/LPS-anchor-stand/anchor-stand.stl|this]] 3D printed stand +
-  * 1 deck +
-  * Computer running [[http://wiki.ros.org/indigo|ROS (Indigo)]] using the [[http://wiki.ros.org/crazyflie|Crazyflie ROS module]] +
-  * Crazyflie client with ZMQ to mix manual and automatic control +
-</WRAP> +
-Here's a video of the current state (March 2016). +
-{{youtube>addbBgewzOU}} +
-</WRAP> +
-</WRAP>+
-====== Hardware description ====== +===== Hardware description =====
-The hardware consists two parts, nodes and decks.+The hardware consists multiple parts:
   * [[projects:lps:node|Loco positioning node]]: Mainly aimed as an anchor but can be used as a tag or UWB radio transceiver and sniffer.   * [[projects:lps:node|Loco positioning node]]: Mainly aimed as an anchor but can be used as a tag or UWB radio transceiver and sniffer.
-  * [[projects:lps:deck|Loco positioning deck]]: USB radio deck to be installed on Crazyflie 2.+  * [[projects:lps:deck|Loco positioning deck]]: USB radio deck to be installed on Crazyflie 2.X
- +  [[projects:lps:roadrunner|Roadrunner]]: Standalone tag aimed at enabling other robots to use the positioning
-====== ROS ====== +
-The ROS module for positioning with the LPS is available on Github: https://github.com/bitcraze/lps-ros. It has been developed and tested on ROS Indigo running on Ubuntu 14.04 +
-To get started from a newly installed ubuntu: +
-  - Install ROS: http://wiki.ros.org/indigo/Installation/Ubuntu +
-  - Create your workspace: http://wiki.ros.org/ROS/Tutorials/InstallingandConfiguringROSEnvironment#Create_a_ROS_Workspace +
-  - Clone https://github.com/bitcraze/lps-ros and https://github.com/whoenig/crazyflie_ros in the workspace src folder +
-  - Run //catkin_make// to build the packages +
-  - Source the workspace //devel/setup.bash// again +
-  - Run //rosdep install bitcraze_lps_estimator// to install dependencies +
-The position of the anchor has to be entered in a configuration file. The file should be //data/anchor_pos.yaml//. An example is present in the data folder: +
-<file yaml anchor_pos.yaml> +
-n_anchors: 6 +
-anchor0_pos:  0,   0, 1.85] +
-anchor1_pos:  0,   2, 1.85] +
-anchor2_pos[  4,   2, 1.85] +
-anchor3_pos[  4,   0, 1.85] +
-anchor4_pos: [1.3,   1, 1.85] +
-anchor5_pos[2.6,   1, 1.85] +
-</file> +
-The positions are in meter, [x, y, z], from the origin.+
-When this file is configured, the //dwm_loc.launch// launch configuration will connect the crazyflie with the right log setup, launch the particle filter and the visualization:
-<code bash>
-$ roslaunch bitcraze_lps_estimator dwm_loc.launch uri:=radio://0/40/2M
-</code>
projects/lps/index.1464183747.txt.gz · Last modified: 2016-05-25 15:42 by arnaud
