User Tools
Site Tools
sidebar
Differences
Link to this comparison view
Next revision
Previous revision
sidebar [2017-03-14 13:49]
tobias [Products]
sidebar [2020-02-11 10:01]
Line 2: Line 2:
     * [[projects:crazyflie:index|Crazyflie 1.0]]     * [[projects:crazyflie:index|Crazyflie 1.0]]
-    * [[projects:crazyflie2:index|Crazyflie 2.0]]+    * [[projects:crazyflie2:index|Crazyflie 2.X]]
 +    * [[projects:bolt:index|Crazyflie Bolt]]
     * [[projects:crazyflie2:expansionboards:index|Expansion decks]]      * [[projects:crazyflie2:expansionboards:index|Expansion decks]]
       * [[projects:crazyflie2:expansionboards:ledring|LED-ring]]       * [[projects:crazyflie2:expansionboards:ledring|LED-ring]]
Line 8: Line 9:
       * [[projects:crazyflie2:expansionboards:bigquad|BigQuad]]       * [[projects:crazyflie2:expansionboards:bigquad|BigQuad]]
       * [[projects:crazyflie2:expansionboards:qi|Qi charging]]       * [[projects:crazyflie2:expansionboards:qi|Qi charging]]
 +      * [[projects:crazyflie2:expansionboards:qi1_2|Qi 1.2 charging]]
       * [[projects:crazyflie2:expansionboards:proto|Prototype]]       * [[projects:crazyflie2:expansionboards:proto|Prototype]]
       * [[projects:crazyflie2:expansionboards:breakout|Breakout]]       * [[projects:crazyflie2:expansionboards:breakout|Breakout]]
       * [[projects:crazyflie2:expansionboards:microsd|Micro-SD]]       * [[projects:crazyflie2:expansionboards:microsd|Micro-SD]]
-      * [[projects:crazyflie2:expansionboards:zranger|Z-ranger expansion deck]]+      * [[projects:crazyflie2:expansionboards:bosch|Bosch Sensors]]
 +      * [[projects:crazyflie2:expansionboards:zranger|Z-ranger]]
 +      * [[projects:crazyflie2:expansionboards:zranger-v2|Z-ranger v2]]
       * [[projects:lps:deck|Loco deck]]       * [[projects:lps:deck|Loco deck]]
 +      * [[projects:crazyflie2:expansionboards:flow|Flow deck]]
 +      * [[projects:crazyflie2:expansionboards:flow-v2|Flow v2]]
 +      * [[projects:crazyflie2:expansionboards:multiranger|Multi-ranger]]
 +      * [[projects:crazyflie2:expansionboards:lighthouse|Lighthouse]]
 +      * [[projects:crazyflie2:expansionboards:mocapmarker|MoCap marker]]
 +      * [[projects:crazyflie2:expansionboards:activemarker|Active marker]]
 +      * [[projects:crazyflie2:expansionboards:aideck|AI-deck]]
     * [[projects:crazyradio:index|Crazyradio]]     * [[projects:crazyradio:index|Crazyradio]]
     * [[projects:crazyradiopa:index|Crazyradio PA]]     * [[projects:crazyradiopa:index|Crazyradio PA]]
Line 18: Line 29:
       * [[projects:lps:node|Node]]       * [[projects:lps:node|Node]]
       * [[projects:lps:deck|Deck]]       * [[projects:lps:deck|Deck]]
 +      * [[projects:lps:roadrunner|Roadrunner]]
     * Accessories     * Accessories
       * [[projects:accessories:chg500:index|Li-Po charger]]       * [[projects:accessories:chg500:index|Li-Po charger]]
 +    * Breakout boards
 +      * [[breakout::flow|Flow breakout]]
     * [[projects:virtualmachine:index|Bitcraze VM]]     * [[projects:virtualmachine:index|Bitcraze VM]]
     * [[projects:dockerbuilderimage:index|The toolbelt and Docker Builder Images]]     * [[projects:dockerbuilderimage:index|The toolbelt and Docker Builder Images]]
Line 28: Line 42:
     * [[doc:crazyflie:client:pycfclient:index|PC client]]     * [[doc:crazyflie:client:pycfclient:index|PC client]]
     * [[doc:lps:index|Loco Positioning System]]     * [[doc:lps:index|Loco Positioning System]]
 +    * [[doc:lighthouse:index|Lighthouse positioning]]
 ==== Misc ==== ==== Misc ====
Line 33: Line 48:
     * [[misc:hacks:index|Builds/hacks/HOW-TOs]]     * [[misc:hacks:index|Builds/hacks/HOW-TOs]]
     * [[misc:investigations:index|Investigations]]     * [[misc:investigations:index|Investigations]]
 +    * [[misc:usbwindows|Windows USB driver]]
     * [[misc:wiki:index|About the wiki]]     * [[misc:wiki:index|About the wiki]]
sidebar.txt · Last modified: 2020-02-11 10:01 by tobias
