doc:crazyflie:api:firmware:deck:howto [2015-12-09 15:49] arnaud [Making your first Deck driver] |
doc:crazyflie:api:firmware:deck:howto [2020-05-12 14:24] (current) kimberly |
====== Making your first Deck driver ====== | ====== Making your first Deck driver ====== | ||
This howto is going to describe step-by-step how to make and flash your first | This howto is going to describe step-by-step how to make and flash your first | ||
- | Crazyflie 2.0 deck driver. See the deck [[doc: | + | Crazyflie 2.X deck driver. See the deck [[doc: |
===== Development environment ===== | ===== Development environment ===== | ||
Line 48: | Line 54: | ||
- | PROJ_OBJ_CF2 | + | PROJ_OBJ |
===== Enabling the driver ===== | ===== Enabling the driver ===== | ||
- | Decks can contain | + | Decks can have a memory that contains its name. In our case the hello driver would be initialised only when a deck identified as " |
<code make config.mk> | <code make config.mk> | ||
Line 62: | Line 68: | ||
DEBUG=1 allows to get more information from the Crazyflie console when it starts. Debug should not be enabled if you intend to fly the Crazyflie out of the lab (it disables the watchdog). | DEBUG=1 allows to get more information from the Crazyflie console when it starts. Debug should not be enabled if you intend to fly the Crazyflie out of the lab (it disables the watchdog). | ||
===== Compile, flash and run! ===== | ===== Compile, flash and run! ===== | ||
Line 68: | Line 79: | ||
- | $ make | + | crazyflie-firmware$ make |
- | $ make cload | + | crazyflie-firmware$ make cload |
Line 75: | Line 86: | ||
CC hello.o | CC hello.o | ||
Line 86: | Line 97: | ||
rm version.c | rm version.c | ||
Restart the Crazyflie you want to bootload in the next | Restart the Crazyflie you want to bootload in the next |
