doc:crazyflie:client:pycfclient:index [2015-09-04 10:02] tobias [Connecting] |
doc:crazyflie:client:pycfclient:index [2017-04-18 16:21] tobias |
- | This page is intended to give an overview on how to use the Crazyflie client, not for installing it. For install instructions go [[projects:crazyflie: | + | This page is intended to give an overview on how to use the Crazyflie client, not for installing it. For install instructions go [[https:// |
The Crazyflie client is used for controlling the Crazyflie, flashing firmware, setting parameters and logging data. The main UI is built up of a number of tabs, where each tab is used for a specific functionality. | The Crazyflie client is used for controlling the Crazyflie, flashing firmware, setting parameters and logging data. The main UI is built up of a number of tabs, where each tab is used for a specific functionality. | ||
Line 9: | Line 9: | ||
Line 22: | Line 20: | ||
- | ===== Connecting | + | ===== Firmware upgrade |
- | There' | + | For updating the Crazyflie firmware there' |
- | <WRAP group> | ||
- | <WRAP half column> | ||
- | * //Scan:// Re-scan for Crazyflies (not you're Crazyflie must be powered on to show up in the list) | ||
- | ===== Firmware upgrade ===== | ||
- | For updating the Crazyflie firmware there' | ||
Line 61: | Line 44: | ||
* Click " | * Click " | ||
- | * Press " | + | * Press " |
* Press " | * Press " | ||
Line 82: | Line 65: | ||
|| Click on the menu **" | || Click on the menu **" | ||
- | || Once the settings has been made press the program button to save them permanently in the Crazyflie flash. | Once the settings has been made press the write button to save them permanently in the Crazyflie 2.0 eeprom. || | + | || Once the settings has been made press the program button to save them permanently in the Crazyflie flash. | Once the settings has been made press the write button to save them permanently in the Crazyflie 2.0 EEPROM. || |
===== Logging ===== | ===== Logging ===== | ||
Line 122: | Line 105: | ||
The //Input device// menu contains a number of different " | The //Input device// menu contains a number of different " | ||
* //Normal:// Just like it says this is the normal mode using only one controller to control a Crazyflie | * //Normal:// Just like it says this is the normal mode using only one controller to control a Crazyflie | ||
- | * //Teacher (RP):// This mode requires two input-devices, | + | * //Teacher (RP):// This mode requires two input-devices, |
- | * //Teacher (RPYT):// This mode requires two input-devices, | + | * //Teacher (RPYT):// This mode requires two input-devices, |
For normal usage just enter the //Normal// menu, select the device you would like to use and the correct mapping. As a device is selected the list of mappings are enabled. | For normal usage just enter the //Normal// menu, select the device you would like to use and the correct mapping. As a device is selected the list of mappings are enabled. | ||
Line 149: | Line 132: | ||
- Advanced flight control settings are available if Advanced mode has been selected (settings are in %): | - Advanced flight control settings are available if Advanced mode has been selected (settings are in %): | ||
Line 224: | Line 211: | ||
- Console output from the Crazyflie | - Console output from the Crazyflie | ||
+ | ===== Loco Positioning ===== | ||
+ | The Loco Positioning tab shows information from the Loco Positioning system when present. | ||
+ | There are three graphs showing 2D projections of the system from three directions. The top left graph shows the system from above, the bottom left shows is it from the front (along the y-axis) while the bottom right shows it from the right side (along the negative x-axis). The graphs can be zoomed and scrolled. | ||
+ | The tab can be used in two modes that is selected with the radio buttons to the right | ||
+ | ==== Position estimate mode ==== | ||
+ | displays the configured anchor positions and the estimated position of the Crazyflie. Can be used to make sure the system is set up correctly and that the estimated position is reasonable. | ||
+ | ==== Anchor identification mode ==== | ||
+ | displays the configured anchor positions. When the crazyflie is close to an anchor this is indicated in the graphs by highlighting it. This mode is useful to identify anchors and verify that the system is correctly configured. | ||
