Once you have connected to the Crazyflie you can just use the Quick connect button next time you start the application.
For updating the Crazyflie firmware there's the possibility to enter bootloader mode and flash new firmware from within the client. The bootloader mode is accessed from the menu Crazyflie→Bootloader.
Timestamp,pm.vbat 9103,3.74252200127 10103,3.74252200127 11103,3.74252200127 12103,3.74252200127 13103,3.74252200127
