doc:crazyflie:client:pycfclient:index [2015-09-04 10:09] tobias [Connecting] |
doc:crazyflie:client:pycfclient:index [2017-12-19 09:11] arnaud [Anchor identification mode] |
- | This page is intended to give an overview on how to use the Crazyflie client, not for installing it. For install instructions go [[projects:crazyflie: | + | This page is intended to give an overview on how to use the Crazyflie client, not for installing it. For install instructions go [[https:// |
The Crazyflie client is used for controlling the Crazyflie, flashing firmware, setting parameters and logging data. The main UI is built up of a number of tabs, where each tab is used for a specific functionality. | The Crazyflie client is used for controlling the Crazyflie, flashing firmware, setting parameters and logging data. The main UI is built up of a number of tabs, where each tab is used for a specific functionality. | ||
Line 9: | Line 9: | ||
====== Main UI ====== | ====== Main UI ====== | ||
- | ===== Connecting | + | ===== Firmware upgrade |
- | There' | + | For updating the Crazyflie firmware there' |
- | <WRAP group> | ||
- | <WRAP half column> | ||
- | * //Scan:// Re-scan for Crazyflies (not you're Crazyflie must be powered on to show up in the list) | ||
- | ===== Firmware upgrade ===== | ||
- | For updating the Crazyflie firmware there' | ||
Line 58: | Line 41: | ||
* Make sure that the Crazyflie is disconnected from the client and powered off | * Make sure that the Crazyflie is disconnected from the client and powered off | ||
* Go to the menu // | * Go to the menu // | ||
- | * For Crazyflie 2.0 hold the button for about 3 seconds when turning it on until the blue LED M2 starts to blink to get into bootloader mode. | + | * For Crazyflie 2.0 hold the button for about 3 seconds when turning it on until the blue LED M2 starts to blink to get into bootloader mode. If a wrong nRF51 firmware has been flashed you might have to start from an un-powered state. Then hold the button and connect power. |
* Click " | * Click " | ||
- | * Press " | + | * Press " |
* Press " | * Press " | ||
Line 73: | Line 56: | ||
* **Pitch trim** Can be programmed permanently with the trim values found to work good in the flight tab. | * **Pitch trim** Can be programmed permanently with the trim values found to work good in the flight tab. | ||
* **Roll trim** Can be programmed permanently with the trim values found to work good in the flight tab. | * **Roll trim** Can be programmed permanently with the trim values found to work good in the flight tab. | ||
- | * **Radio channel** Can be set to anything between 0 and 125, correspond to a frequency from 2400MHz to 2525MHz. In most countries channel 0 to 80 is OK to use but this should be checked with you local regulations. If using 2M datarate, the copter channels should be 2MHz apart. | + | * **Radio channel** Can be set to anything between 0 and 125, correspond to a frequency from 2400MHz to 2525MHz. In most countries channel 0 to 80 is OK to use but this should be checked with you local regulations. If using 2M datarate, the copter channels should be 2 apart (2MHz). |
* **Radio bandwidth** This can set the radio bandwidth to 250k, 1M or 2M. A lower bandwidth has longer range but has higher chance of collision. When used inside sometimes it is better to use 1M or 2M as it decreases the risk of collision with WiFi. | * **Radio bandwidth** This can set the radio bandwidth to 250k, 1M or 2M. A lower bandwidth has longer range but has higher chance of collision. When used inside sometimes it is better to use 1M or 2M as it decreases the risk of collision with WiFi. | ||
* **Radio address** (advanced) will set the shock burst address used for communicating. Note that if you change this then you will have to set the address correctly in the connect dialog. | * **Radio address** (advanced) will set the shock burst address used for communicating. Note that if you change this then you will have to set the address correctly in the connect dialog. | ||
Line 82: | Line 65: | ||
|| Click on the menu **" | || Click on the menu **" | ||
- | || Once the settings has been made press the program button to save them permanently in the Crazyflie flash. | Once the settings has been made press the write button to save them permanently in the Crazyflie 2.0 eeprom. || | + | || Once the settings has been made press the program button to save them permanently in the Crazyflie flash. | Once the settings has been made press the write button to save them permanently in the Crazyflie 2.0 EEPROM. || |
===== Logging ===== | ===== Logging ===== | ||
Line 107: | Line 90: | ||
- | Follow the instructions to detect the axis or button that you would like to map to the functionality. If you would like to map the functionality to two axis (like right/ | + | Follow the instructions to detect the axis or button that you would like to map to the functionality. If you would like to map the functionality to two axis (like right/ |
Go though all the functionality you would like to map by pressing the //Detect// button for each. To be able to save the mapping you will at least have to map roll, pitch, yaw and thrust. | Go though all the functionality you would like to map by pressing the //Detect// button for each. To be able to save the mapping you will at least have to map roll, pitch, yaw and thrust. | ||
Line 122: | Line 105: | ||
The //Input device// menu contains a number of different " | The //Input device// menu contains a number of different " | ||
* //Normal:// Just like it says this is the normal mode using only one controller to control a Crazyflie | * //Normal:// Just like it says this is the normal mode using only one controller to control a Crazyflie | ||
- | * //Teacher (RP):// This mode requires two input-devices, | + | * //Teacher (RP):// This mode requires two input-devices, |
- | * //Teacher (RPYT):// This mode requires two input-devices, | + | * //Teacher (RPYT):// This mode requires two input-devices, |
For normal usage just enter the //Normal// menu, select the device you would like to use and the correct mapping. As a device is selected the list of mappings are enabled. | For normal usage just enter the //Normal// menu, select the device you would like to use and the correct mapping. As a device is selected the list of mappings are enabled. | ||
Line 149: | Line 132: | ||
- Advanced flight control settings are available if Advanced mode has been selected (settings are in %): | - Advanced flight control settings are available if Advanced mode has been selected (settings are in %): | ||
Line 224: | Line 211: | ||
- Console output from the Crazyflie | - Console output from the Crazyflie | ||
+ | ===== Loco Positioning ===== | ||
+ | The Loco Positioning tab shows information from the Loco Positioning system when present. | ||
+ | There are three graphs showing 2D projections of the system from three directions. The top left graph shows the system from above, the bottom left shows is it from the front (along the y-axis) while the bottom right shows it from the right side (along the negative x-axis). The graphs can be zoomed and scrolled. | ||
+ | The tab can be used in two modes that is selected with the radio buttons to the right | ||
+ | ==== Position estimate mode ==== | ||
+ | Displays the configured anchor positions and the estimated position of the Crazyflie. Can be used to make sure the system is set up correctly and that the estimated position is reasonable. | ||
+ | - Plot for X/Y (top view) showing anchors and Crazyflie | ||
+ | - Plot for X/Z showing anchors and Crazyflie | ||
+ | - Plot for Y/Z showing anchors and Crazyflie | ||
+ | - Sets the graph mode | ||
+ | * //Position estimate// - Normal viewing mode | ||
+ | * //Anchor identification// | ||
+ | - Indicates if anchors are communicating with Crazyflie (i.e anchors are up and running) | ||
+ | - Fit and center all data in graphs | ||
+ | - Used to set anchor positions (see below) | ||
+ | When setting the anchor position there' | ||
+ | * //White// - No position exists for this anchor (i.e the position has not been read yet) | ||
+ | * //Red// - Position has been read from the anchor and it differs from the currently shown value in the input box | ||
+ | * //Green// - Position has been read from the anchor and it is the same as the currently shown value in the input box | ||
+ | The positions of the anchors is continuously read in the background and as positions comes in or input box values changes the colors will be set accordingly. There' | ||
+ | * //Get from anchors// - Fills the input boxes with the positions read from the anchors | ||
+ | * //Write to anchors// - Writes the currently shown values in the input boxes to the anchors. In order to check that the write has been successful wait about 10s and all the fields should turn green as the positions are read back. If some of the fields are still red, try pressing the button again. | ||
+ | ==== Anchor identification mode ==== | ||
+ | displays the configured anchor positions. When the crazyflie is close to an anchor this is indicated in the graphs by highlighting it. This mode is useful to identify anchors and verify that the system is correctly configured. | ||
+ | - Current system mode indication. The system must be in TWR mode for the anchor identification mode to be available. | ||
