Follow the instructions to detect the axis or button that you would like to map to the functionality. If you would like to map the functionality to two axis (like right/left sholder-button) then select Combined axis detection and follow the instructions.
Timestamp,pm.vbat 9103,3.74252200127 10103,3.74252200127 11103,3.74252200127 12103,3.74252200127 13103,3.74252200127
Displays the configured anchor positions and the estimated position of the Crazyflie. Can be used to make sure the system is set up correctly and that the estimated position is reasonable.
When setting the anchor position there's three colors to indicate the status:
The positions of the anchors is continuously read in the background and as positions comes in or input box values changes the colors will be set accordingly. There's also two buttons used for the settings:
