doc:crazyflie:client:pycfclient:index [2017-03-29 16:34] bjorn |
doc:crazyflie:client:pycfclient:index [2017-04-18 16:19] tobias [Main UI] |
Line 9: | Line 9: | ||
Line 22: | Line 20: | ||
Line 150: | Line 150: | ||
- Advanced flight control settings are available if Advanced mode has been selected (settings are in %): | - Advanced flight control settings are available if Advanced mode has been selected (settings are in %): |
