doc:crazyflie:crtp:generic_setpoint [2018-02-15 08:59] arnaud |
doc:crazyflie:crtp:generic_setpoint [2018-02-16 16:20] arnaud |
Line 18: | Line 18: | ||
| 1 | [[doc: | | 1 | [[doc: | ||
| 2 | [[doc: | | 2 | [[doc: | ||
+ | | 3 | [[doc: | ||
+ | | 4 | [[doc: | ||
+ | | 5 | [[doc: | ||
+ | | 6 | [[doc: | ||
+ | | 7 | [[doc: | ||
==== Stop ==== | ==== Stop ==== | ||
Line 51: | Line 57: | ||
+ | ==== CPPM Emulation ==== | ||
+ | CRTP packet containing an emulation of CPPM channels | ||
+ | Channels have a range of 1000-2000 with a midpoint of 1500 | ||
+ | Supports the ordinary RPYT channels plus up to MAX_AUX_RC_CHANNELS auxiliary channels. | ||
+ | Auxiliary channels are optional and transmitters do not have to transmit all the data | ||
+ | unless a given channel is actually in use (numAuxChannels must be set accordingly) | ||
+ | Current aux channel assignments: | ||
+ | * AuxChannel0: | ||
+ | Payload format: | ||
+ | <code c> | ||
+ | #define MAX_AUX_RC_CHANNELS 10 | ||
+ | static float s_CppmEmuRollMaxRateDps = 720.0f; // For rate mode | ||
+ | static float s_CppmEmuPitchMaxRateDps = 720.0f; // For rate mode | ||
+ | static float s_CppmEmuRollMaxAngleDeg = 50.0f; // For level mode | ||
+ | static float s_CppmEmuPitchMaxAngleDeg = 50.0f; // For level mode | ||
+ | static float s_CppmEmuYawMaxRateDps = 400.0f; // Used regardless of flight mode | ||
+ | struct cppmEmuPacket_s { | ||
+ | struct { | ||
+ | uint8_t numAuxChannels : 4; // Set to 0 through MAX_AUX_RC_CHANNELS | ||
+ | uint8_t reserved : 4; | ||
+ | } hdr; | ||
+ | uint16_t channelRoll; | ||
+ | uint16_t channelPitch; | ||
+ | uint16_t channelYaw; | ||
+ | uint16_t channelThrust; | ||
+ | uint16_t channelAux[MAX_AUX_RC_CHANNELS]; | ||
+ | } __attribute__((packed)); | ||
+ | ==== Altitude Hold ==== | ||
+ | Set the Crazyflie vertical velocity and roll/pitch angle. | ||
+ | <code c> | ||
+ | struct altHoldPacket_s { | ||
+ | float roll; // rad | ||
+ | float pitch; | ||
+ | float yawrate; | ||
+ | float zVelocity; | ||
+ | ==== Hover ==== | ||
+ | Set the Crazyflie absolute height and velocity in the body coordinate system. | ||
+ | <code c> | ||
+ | struct hoverPacket_s { | ||
+ | float vx; // m/s in the body frame of reference | ||
+ | float vy; // ... | ||
+ | float zDistance; | ||
+ | ==== Full State ==== | ||
+ | Set the full state. | ||
+ | <code c> | ||
+ | struct fullStatePacket_s { | ||
+ | int16_t x; // position - mm | ||
+ | int16_t y; | ||
+ | int16_t z; | ||
+ | int16_t vx; // velocity - mm / sec | ||
+ | int16_t vy; | ||
+ | int16_t vz; | ||
+ | int16_t ax; // acceleration - mm / sec^2 | ||
+ | int16_t ay; | ||
+ | int16_t az; | ||
+ | int32_t quat; // compressed quaternion, see quatcompress.h | ||
+ | int16_t rateRoll; | ||
+ | int16_t ratePitch; // (NOTE: limits to about 5 full circles per sec. | ||
+ | int16_t rateYaw; | ||
+ | === Position === | ||
+ | Set the absolute postition and orientation. | ||
+ | <code c> | ||
+ | float x; // Position in m | ||
+ | float y; | ||
+ | float z; | ||
+ | float yaw; // Orientation in degree | ||
