doc:crazyflie:crtp:generic_setpoint
Generic Setpoint CRTP Port
Port Channel Name
7 0 Generic setpoint
Generic setpoint
Byte Value Note
0 ID ID of the setpoint packet
1.. Payload Format defined per ID
Defined IDs:
Stop
Velocity World
Payload format:
struct velocityPacket_s {
  float vx;        // m in the world frame of reference
  float vy;        // ...
  float vz;        // ...
  float yawrate;  // deg/s
} __attribute__((packed));
Z Distance
Set the Crazyflie absolute height and roll/pitch angles. Used for Z-ranger.
Payload format:
struct zDistancePacket_s {
  float roll;            // deg
  float pitch;           // ...
  float zDistance;        // m in the world frame of reference
doc/crazyflie/crtp/generic_setpoint.1518681572.txt.gz · Last modified: 2018-02-15 08:59 by arnaud
