doc:crazyflie:crtp:localization [2017-05-16 15:53] arnaud [Generic Localization] |
doc:crazyflie:crtp:localization [2019-09-05 15:11] kimberly |
+ | https:// | ||
====== Localization CRTP port ====== | ====== Localization CRTP port ====== | ||
Line 30: | Line 39: | ||
^ ID ^ Packet ^ | ^ ID ^ Packet ^ | ||
| 2 | LPP Short packet tunnel | | | 2 | LPP Short packet tunnel | | ||
- | | 3 | Enable emergency stop: stops all motors | + | | 3 | Enable emergency stop | |
- | | 4 | Reset emergency stop timeout, see bellow. | + | | 4 | Reset emergency stop timeout | |
==== LPP Short packet tunnel ==== | ==== LPP Short packet tunnel ==== | ||
Line 37: | Line 46: | ||
Packet used to send LPP short packet to the loco positioning system. The payload is sent to the sytem as an [[doc: | Packet used to send LPP short packet to the loco positioning system. The payload is sent to the sytem as an [[doc: | ||
+ | ==== Emergency stop ==== | ||
+ | When received, the stabilizer loop is set in emergency stop mode which stops all the motors. The loop stays in emergency stop mode until the situation is reset. | ||
+ | ==== Reset emergency stop timeout ==== | ||
+ | At startup the emergency stop timeout is disabled. | ||
+ | The first time this packet is receive, the emergency stop timeout is enabled with a timeout of 1 second. | ||
+ | This packet should then be sent, and received by the Crazyflie, at least once every 1 second otherwise the stabilizer loop will be set in emergency stop and all motors will stop. | ||
