https://www.bitcraze.io/docs/crazyflie-firmware/master/ctrp_localization/
This port groups various packets related to localization. It exposes two channels:
| Port | Channel | Name |
| 6 | 0 | External Position |
| 6 | 1 | Generic localization |
This packet is used to send the Crazyflie position as acquired by an external system. The main use it to send the position acquired by a motion capture system to push it in the Extended Kalman Filter to allow the Crazyflie to calculate an estimate and control its state.
The packet format is:
struct CrtpExtPosition { float x; // in m float y; // in m float z; // in m } __attribute__((packed));
This channel intends to host packets useful for the localization subsystem. It has been created to serve the Loco Positioning System packets but can be used for more general things like GPS NMEA or binary streams. The format of the packet is:
| Byte | Value | Note |
| 0 | ID | ID of the packet |
| 1.. | Payload | Packet payload. Format defined per ID |
| ID | Packet |
| 2 | LPP Short packet tunnel |
| 3 | Enable emergency stop |
| 4 | Reset emergency stop timeout |
Packet used to send LPP short packet to the loco positioning system. The payload is sent to the sytem as an LPP Short Packet.
When received, the stabilizer loop is set in emergency stop mode which stops all the motors. The loop stays in emergency stop mode until the situation is reset.
At startup the emergency stop timeout is disabled.
The first time this packet is receive, the emergency stop timeout is enabled with a timeout of 1 second.
This packet should then be sent, and received by the Crazyflie, at least once every 1 second otherwise the stabilizer loop will be set in emergency stop and all motors will stop.
