Both sides previous revision Previous revision | Last revision Both sides next revision | ||
doc:crazyflie:dev:env:python [2015-01-29 13:50] arnaud |
doc:crazyflie:dev:env:python [2015-07-15 16:31] 127.0.0.1 external edit |
+ | ====== Setting-up python development environment ====== | ||
+ | Up-to-date information on how to run the python client from source can be found in the project [[https:// | ||
+ | ===== Windows ===== | ||
+ | Install dependencies: | ||
+ | - Python 2.7 32bit (x86) from https:// | ||
+ | - PyQT4 for Python 2.7 32bit from http:// | ||
+ | - Scipy for Python 2.7 32bit from http:// | ||
+ | - PyQTGraph for Python 2.7 32bit from http:// | ||
+ | To install python dependencies you can use PIP, a python package manager that is installed with python. To use it launch a Windows command line client by typing " | ||
+ | C: | ||
+ | C: | ||
+ | Download or clone the Crazyflie client. You can download a zip of the sourcec ode from [[https:// | ||
+ | Now that you have a copy of the Client source code, download SDL2 32bit from the SDL website (http:// | ||
+ | You can now run the client from the command line window: | ||
+ | cd <folder where the source code is cloned> | ||
+ | C: | ||
