doc:crazyflie:dev:env:python
Setting-up python development environment
Up-to-date information on how to run the python client from source can be found in the project readme. This page aims at being a more user-friendly walk-throw.
Windows
Install dependencies:
  1. Python 2.7 32bit (x86) from https://www.python.org/downloads/windows/
  2. PyQTGraph for Python 2.7 32bit from http://www.pyqtgraph.org/
To install python dependencies you can use PIP, a python package manager that is installed with python. To use it launch a Windows command line client by typing “windows key” then “cmd”. In the command line windows type the following (you can copy-paste the lines):
C:\Python27\Scripts\pip.exe install pyusb==1.0.0b2
C:\Python27\Scripts\pip.exe install pysdl2
Download or clone the Crazyflie client. You can download a zip of the sourcec ode from github or clone it using git for windows or a git GUI client.
Now that you have a copy of the Client source code, download SDL2 32bit from the SDL website (http://libsdl.org/download-2.0.php) and copy the file SDL2.dll in the source folder.
You can now run the client from the command line window:
cd <folder where the source code is cloned>
C:\Python27\Python.exe bin\cfclient
doc/crazyflie/dev/env/python.txt · Last modified: 2021-06-24 14:48 by kimberly
