User Tools
Site Tools
doc:crazyflie:syslink:index
Differences
Link to this comparison view
Next revision
Previous revision
doc:crazyflie:syslink:index [2015-07-15 16:31]
127.0.0.1 external edit
doc:crazyflie:syslink:index [2020-05-12 14:14]
Line 1: Line 1:
 +This page has deprecated and moved to the new documentation framework of the main Bitcraze website. Please go to [[https://www.bitcraze.io/documentation/system/]]
 +</WRAP>
 ====== Syslink protocol ====== ====== Syslink protocol ======
Line 7: Line 12:
 In Crazyflie 2.0 syslink is transmitted on serial port at 1MBaud. It is a packet-based protocol. In Crazyflie 2.0 syslink is transmitted on serial port at 1MBaud. It is a packet-based protocol.
-<ditaa noedgesep>+<code>
   |   START   | TYPE | LEN | DATA        |   CKSUM   |   |   START   | TYPE | LEN | DATA        |   CKSUM   |
-</ditaa>+</code>
   * **START** is 2 bytes constant, 0xBC 0xCF.   * **START** is 2 bytes constant, 0xBC 0xCF.
Line 109: Line 114:
 <ditaa noedgesep> <ditaa noedgesep>
- | Flags | ISET | VBAT |+ | Flags | VBAT | ISET |
           4       4           4       4
Line 116: Line 121:
 <WRAP column> <WRAP column>
   * **Flags**: Bit0: Charging. Bit1: USB Powered.   * **Flags**: Bit0: Charging. Bit1: USB Powered.
-  * **ISET**: IEEE single float. Charge current in milli-Ampers.
   * **VBAT**: IEEE single float. Battery voltage.   * **VBAT**: IEEE single float. Battery voltage.
 +  * **ISET**: IEEE single float. Charge current in milli-Ampers.
 </WRAP> </WRAP>
doc/crazyflie/syslink/index.txt · Last modified: 2020-05-12 14:14 by kimberly
