doc:crazyflie:syslink:index [2016-04-15 16:39] arnaud [SYSLINK_PM_BATTERY_STATE] |
doc:crazyflie:syslink:index [2020-05-12 14:14] (current) kimberly |
| ====== Syslink protocol ====== | ====== Syslink protocol ====== | ||
| Line 7: | Line 12: | ||
| In Crazyflie 2.0 syslink is transmitted on serial port at 1MBaud. It is a packet-based protocol. | In Crazyflie 2.0 syslink is transmitted on serial port at 1MBaud. It is a packet-based protocol. | ||
| - | <ditaa noedgesep> | + | <code> |
| - | </ditaa> | + | </code> |
| * **START** is 2 bytes constant, 0xBC 0xCF. | * **START** is 2 bytes constant, 0xBC 0xCF. | ||
| Line 116: | Line 121: | ||
| <WRAP column> | <WRAP column> | ||
| * **Flags**: Bit0: Charging. Bit1: USB Powered. | * **Flags**: Bit0: Charging. Bit1: USB Powered. | ||
| - | * **ISET**: IEEE single float. Charge current in milli-Ampers. | ||
| * **VBAT**: IEEE single float. Battery voltage. | * **VBAT**: IEEE single float. Battery voltage. | ||
| + | * **ISET**: IEEE single float. Charge current in milli-Ampers. | ||
