doc:crazyradio:install_windows_zadig [2014-01-30 12:08] arnaud [Install the driver] |
doc:crazyradio:install_windows_zadig [2021-06-24 16:54] (current) kimberly |
| ====== Crazyradio manual windows installation using zadig ====== | ====== Crazyradio manual windows installation using zadig ====== | ||
| Line 26: | Line 29: | ||
| + | ===== Troubleshooting ===== | ||
| + | If things does not work check that the Crazyradio appears as a libusb device in the Windows device manager. If it is not the case try to reinstall the driver as described above. | ||
| + | If you are having problems with the radio not working all the time (like scanning but not connecting) you can try to install the libUSBK driver, it have been behaving a bit better to some version of pyusb: | ||
