doc:crazyradio:usb:index [2012-11-11 17:56] arnaud [Set radio channel] |
doc:crazyradio:usb:index [2013-01-05 23:35] arnaud [Dongle configuration summary] |
Line 18: | Line 18: | ||
To send a packet the following sequence must be followes: | To send a packet the following sequence must be followes: | ||
* Send the packet to EP1_OUT. Its length should be between 1 to 32Bytes | * Send the packet to EP1_OUT. Its length should be between 1 to 32Bytes | ||
- | * Read the ACK from EP1_IN. The first by is the transfers status and the following bytes are the content of the ACK payload, if any. | + | * Read the ACK from EP1_IN. The first byte is the transfers status and the following bytes are the content of the ACK payload, if any. |
Line 41: | Line 41: | ||
| 0 | Ack received | | 0 | Ack received | ||
- | ==== Dongle configuration | + | ==== Dongle configuration |
Line 54: | Line 54: | ||
| 0x40 | ACK_ENABLE (0x10) | | 0x40 | ACK_ENABLE (0x10) | ||
+ | | 0x40 | SCAN_CHANNELS (0x21) | ||
+ | | 0xC0 | SCAN_CHANNELS (0x21) | ||
