EP0 | Control | Control endpoint. Used to configure the dongle |
EP1IN/OUT | Bulk | Data endpoints. Used to send and receive radio packets |
Status Bit | Role |
4..7 | Number of retransmition |
2..3 | Reserved |
1 | Power detector |
0 | Ack received |
bmRequestType | bRequest | wValue | wIndex | wLength | data |
0x40 | SET_RADIO_CHANNEL (0x01) | channel | Zero | Zero | None |
0x40 | SET_RADIO_ADDRESS (0x02) | Zero | Zero | 5 | Address |
0x40 | SET_DATA_RATE (0x03) | Datarate | Zero | Zero | None |
0x40 | SET_RADIO_POWER (0x04) | Power | Zero | Zero | None |
0x40 | SET_RADIO_ARD (0x05) | ARD | Zero | Zero | None |
0x40 | SET_RADIO_ARC (0x06) | ARC | Zero | Zero | None |
0x40 | ACK_ENABLE (0x10) | Active | Zero | Zero | None |
0x40 | SET_CONT_CARRIER (0x20) | Active | Zero | Zero | None |
0x40 | LAUNCH_BOOTLOADER (0xFF) | Zero | Zero | Zero | None |
Value | Radio datarate |
0 | 250Kbps |
1 | 1MBps |
2 | 2Mbps (Default) |
Value | Power |
0 | -18dBm |
1 | -12dBm |
2 | -6dBm |
3 | 0dBm |
Possible values for ARD:
Value | ARD wait time |
0x00 | 250us |
0x01 | 500us |
0x0F | 4000us |
Value | Ack payload length |
0x80 | 0Byte |
0x81 | 1Byte |
0xA0 | 32Bytes |
Active values | Meaning |
0 | Auto ack deactivated |
Not 0 | Auto ack enable (default) |
0 | Dongle working normally (default) |
Not 0 | Dongle in continuous carrier mode |
