doc:crazyradio:usb:index [2013-01-05 23:35] arnaud [Dongle configuration summary] |
doc:crazyradio:usb:index [2013-08-03 01:54] fred Fixed typos |
- | This page document | + | This page documents |
- | The USB devices | + | The USB devices |
Line 14: | Line 14: | ||
- | The radio dongle | + | When the radio dongle |
- | To send a packet the following sequence must be followes: | + | To send a packet, the following sequence must be followed: |
- | * Send the packet to EP1_OUT. Its length should be between 1 to 32Bytes | + | * Send the packet to EP1_OUT. Its length should be between 1 to 32 Bytes |
- | * Read the ACK from EP1_IN. The first byte is the transfers | + | * Read the ACK from EP1_IN. The first byte is the transfer |
Line 36: | Line 36: | ||
^ Status | ^ Status | ||
- | | 4..7 | Number of retransmition | + | | 4..7 | Number of retransmission |
| 2..3 | Reserved | | 2..3 | Reserved | ||
| 1 | Power detector | | 1 | Power detector | ||
- | | 0 | + | | 0 |
==== Dongle configuration and functions summary ==== | ==== Dongle configuration and functions summary ==== | ||
Line 46: | Line 46: | ||
- | | 0x40 | SET_RADIO_CHANNEL (0x01) | channel | + | | 0x40 | SET_RADIO_CHANNEL (0x01) |
- | | 0x40 | SET_RADIO_ADDRESS (0x02) | Zero | Zero | 5 | Address | | + | | 0x40 | SET_RADIO_ADDRESS (0x02) |
- | | 0x40 | SET_DATA_RATE (0x03) | + | | 0x40 | SET_DATA_RATE (0x03) |
- | | 0x40 | SET_RADIO_POWER (0x04) | + | | 0x40 | SET_RADIO_POWER (0x04) |
- | | 0x40 | SET_RADIO_ARD (0x05) | + | | 0x40 | SET_RADIO_ARD (0x05) |
- | | 0x40 | SET_RADIO_ARC (0x06) | + | | 0x40 | SET_RADIO_ARC (0x06) |
- | | 0x40 | ACK_ENABLE (0x10) | + | | 0x40 | ACK_ENABLE (0x10) |
- | | 0x40 | SET_CONT_CARRIER (0x20) | + | | 0x40 | SET_CONT_CARRIER (0x20) |
- | | 0x40 | SCAN_CHANNELS | + | | 0x40 | START_SCAN_CHANNELS |
- | | 0xC0 | SCAN_CHANNELS | + | | 0xC0 | GET_SCAN_CHANNELS |
- | | 0x40 | LAUNCH_BOOTLOADER (0xFF) | Zero | Zero | Zero | None | | + | | 0x40 | LAUNCH_BOOTLOADER (0xFF) |
==== Set radio channel ==== | ==== Set radio channel ==== | ||
Line 63: | Line 63: | ||
| 0x40 | SET_RADIO_CHANNEL (0x01) | channel | | 0x40 | SET_RADIO_CHANNEL (0x01) | channel | ||
- | The nrf24L chips provides 126 Channels of 1MHz from 2400MHz to 2525MHz. The channel parameter shall be between 0 and 125 (if not the command will be ignored). | + | The nRF24LU1 chip provides 126 Channels of 1MHz from 2400MHz to 2525MHz. The channel parameter shall be between 0 and 125 (if not, the command will be ignored). |
- | The radio channel is set as soon as the USB setup transaction is completed which takes about 1ms. The new frequency is going to be used for the following | + | The radio channel is set as soon as the USB setup transaction is completed, which takes about 1ms. The new frequency is going to be used for the following |
==== Set radio address ==== | ==== Set radio address ==== | ||
Line 74: | Line 74: | ||
The packet sent by the radio contains a 5 bytes address. The same address must be configured in the receiver for the communication to work. | The packet sent by the radio contains a 5 bytes address. The same address must be configured in the receiver for the communication to work. | ||
- | The address must follow the requirement of the section 6.4.3.2 of the nRF24LU1 documentation: | + | The address must follow the requirement of section 6.4.3.2 of the nRF24LU1 documentation: |
Line 84: | Line 84: | ||
The default address is 0xE7E7E7E7E7. | The default address is 0xE7E7E7E7E7. | ||
- | ==== Set datarate | + | ==== Set data rate ==== |
- | Possible values for the datarate: | + | Possible values for the data rate: |
- | ^ Value ^ Radio datarate | + | ^ Value ^ Radio data rate ^ |
| 0 | 250Kbps | | 0 | 250Kbps | ||
| 1 | 1MBps | | | 1 | 1MBps | | ||
Line 115: | Line 115: | ||
- | After sending a packet the radio automatically waits for an acknowledge. ARD and ARC permits | + | After sending a packet the radio automatically waits for an acknowledge. ARD and ARC permit |
- | The delay ARD depends | + | The delay ARD depends |
Possible values for ARD: | Possible values for ARD: | ||
Line 126: | Line 126: | ||
| 0x0F | 4000us | | 0x0F | 4000us | ||
- | ^ Value ^ Ack payload length ^ | + | ^ Value ^ ACK payload length ^ |
| 0x80 | 0Byte | | | 0x80 | 0Byte | | ||
| 0x81 | 1Byte | | | 0x81 | 1Byte | | ||
Line 132: | Line 132: | ||
| 0xA0 | 32Bytes | | 0xA0 | 32Bytes | ||
- | ARC configures the number of time the radio will retry a transfer if the Ack has not been received, it can be set from 0 to 15. | + | ARC configures the number of times the radio will retry a transfer if the ACK has not been received, it can be set from 0 to 15. |
By default ARD=32Bytes (0xA0) and ARC=3. | By default ARD=32Bytes (0xA0) and ARC=3. | ||
Line 141: | Line 141: | ||
| 0x40 | ACK_ENABLE (0x10) | | 0x40 | ACK_ENABLE (0x10) | ||
- | By default Crazyradio is configured with auto ack enable. It means that after transmiting | + | By default, the Crazyradio is configured with auto ACK enabled. This means that after transmitting |
^ Active values ^ Meaning | ^ Active values ^ Meaning | ||
- | | 0 | Auto ack deactivated | + | | 0 | Auto ACK deactivated |
- | | Not 0 | Auto ack enable (default) | | + | | Not 0 | Auto ACK enable (default) | |
==== Continuous carrier mode ==== | ==== Continuous carrier mode ==== | ||
Line 152: | Line 152: | ||
- | The nRF24L radio chip provides a test mode in which a continous | + | The nRF24L radio chip provides a test mode in which a continuous |
- | while the continuous carrier mode is active it is possible to set channel and power to change the frequency and power of the emitted wave. | + | While the continuous carrier mode is active, it is possible to set channel and power to change the frequency and power of the emitted wave. |
| 0 | Dongle working normally (default) | | | 0 | Dongle working normally (default) | | ||
| Not 0 | Dongle in continuous carrier mode | | | Not 0 | Dongle in continuous carrier mode | | ||
+ | ==== Channels scanning ==== | ||
+ | This function is implemented in Crazyradio version 0.5 and over. | ||
+ | | 0x40 | START_SCAN_CHANNELS (0x21) | Start | Stop | Length | ||
+ | | 0xC0 | GET_SCAN_CHANNELS (0x21) | ||
+ | Scan a range of channels and compile a list of channel from which an ACK has been received. The command START_SCAN_CHANNELS should be executed first with start being the first scanned channel and stop the last one. Those should be within 0 to 125. The data is the packet payload sent on each channel, it should be at least one byte long. | ||
+ | All parameters, except the channel, are used unmodified during the scan. If the data rate is set to 2MBPs the scan is done every second channel. To get the list of channels that answered, GET_SCANN_CHANNELS should be called just after a scan. Up to 63 bytes are returned corresponding to up to 63 channels on which the packet was acknowledged. | ||
+ | Note: After scanning, the channel will be set to the last scanned channel. | ||
==== Launch bootloader ==== | ==== Launch bootloader ==== | ||
Line 165: | Line 179: | ||
- | This command is used to launch the Nordic semiconductor USB bootloader. After sending this command a USB reset shall be emitted which will trigger the dongle to start the bootloader. After sending this command the Dongle is only waiting for a USB reset which means that any other commands or data will be ignored. | + | This command is used to launch the Nordic semiconductor USB bootloader. After sending this command, a USB reset shall be emitted which will trigger the dongle to start the bootloader. After sending this command, the Dongle is only waiting for a USB reset which means that any other commands or data will be ignored. |
- | The bootloader is pre-loaded by Nordic Semi. in the nRF24LU1 chip at the address 0x7800. The Crazyradio firmware will jump to it when the sequence LAUCH_BOOTLOADER | + | The bootloader is pre-loaded by Nordic Semi. in the nRF24LU1 chip at the address 0x7800. The Crazyradio firmware will jump to it when the sequence LAUCH_BOOTLOADER |
A PC client for the bootloader is part of the Crazyflie ground station program. | A PC client for the bootloader is part of the Crazyflie ground station program. | ||
===== Radio protocol ===== | ===== Radio protocol ===== | ||
+ | The Crazyradio dongle is currently only operating in PTX mode. To get a downlink from the copter the ACK payload is used, which means that data are received only when data are sent. In the case of Crazyflie, to have bidirectional communication even when no data is send, a null packet (0xff) is sent periodically to pull the downlink data stream. | ||
+ | For Crazyflie the communication protocol is described in [[projects: |
