This page documents the protocol used in version 0.40 of the Crazyradio dongle. Future version (up to 1.0) will be kept compatible.
| Status Bit | Role |
| 4..7 | Number of retransmission |
| 2..3 | Reserved |
| 1 | Power detector |
| 0 | ACK received |
| 0x40 | SET_DATA_RATE (0x03) | Data rate | Zero | Zero | None |
| 0x40 | START_SCAN_CHANNELS (0x21) | Start | Stop | Length | Packet |
| 0xC0 | GET_SCAN_CHANNELS (0x21) | Zero | Zero | 63 | Result |
| Value | Radio data rate |
| 0 | 250Kbps |
| 1 | 1MBps |
| 2 | 2Mbps (Default) |
| Value | Power |
| 0 | -18dBm |
| 1 | -12dBm |
| 2 | -6dBm |
| 3 | 0dBm |
Possible values for ARD:
| Value | ARD wait time |
| 0x00 | 250us |
| 0x01 | 500us |
| 0x0F | 4000us |
| Value | ACK payload length |
| 0x80 | 0Byte |
| 0x81 | 1Byte |
| 0xA0 | 32Bytes |
| Active values | Meaning |
| 0 | Auto ACK deactivated |
| Not 0 | Auto ACK enable (default) |
Note: After scanning, the channel will be set to the last scanned channel.
