doc:lighthouse:bootloader [2019-02-26 17:22] arnaud |
doc:lighthouse:bootloader [2019-03-10 12:11] arnaud [Bootloader protocol] |
====== Lighthouse deck bootloader ====== | ====== Lighthouse deck bootloader ====== | ||
- | <WRAP center round important 70%> | ||
- | **Warning**: | ||
The [[projects: | The [[projects: | ||
Line 13: | Line 9: | ||
- | There is two UARTs on the deck, UART0 on the Crazyflie deck interface and UART1 on 2.54mm soldering pads available for external communication. The bootloader is available on both UARTs. The UARTs are setup with a baudrate of 115200. | + | There is two UARTs on the deck, UART0 on the Crazyflie deck interface and UART1 on 2.54mm soldering pads available for external communication. The bootloader is available on both UARTs. The UARTs are setup with a baudrate |
+ | **Warning**: | ||
When using the UART, commands are sent on the RX line and answer will be sent back by the bootloader on the TX line. Since the bootloader and the Flash SPI bus are working much faster than the UART, there is no need for flow control. | When using the UART, commands are sent on the RX line and answer will be sent back by the bootloader on the TX line. Since the bootloader and the Flash SPI bus are working much faster than the UART, there is no need for flow control. | ||
Line 40: | Line 41: | ||
- | All numbers are expressed | + | All numbers are encoded |
Line 67: | Line 68: | ||
^ Byte # ^ Value ^ Note ^ | ^ Byte # ^ Value ^ Note ^ | ||
| 0-(RLEN-1) | | 0-(RLEN-1) | ||
