There is two UARTs on the deck, UART0 on the Crazyflie deck interface and UART1 on 2.54mm soldering pads available for external communication. The bootloader is available on both UARTs. The UARTs are setup with a baudrate of 115200.
Sent to the bootloader:
| Byte # | Value | Note |
| 0 | 0x00 | Boot command |
| 1-2 | WLEN | Write length |
| 3-4 | RLEN | Read length |
Received from the bootloader:
The version string format is a base 10 integer number in ascii indicating the version. For example “1”. It follows the rules of the C function strtol() to be decoded so the string can start with white-space, followed by an optional “+” or “=” followed by decimal digits. The decoding stops at the first non-digit character.
