doc:lighthouse:bootloader [2019-02-20 08:06] arnaud |
doc:lighthouse:bootloader [2020-03-05 20:52] kristoffer |
- | ====== Lighthouse deck bootloader | + | <WRAP center round important 60%> |
+ | https:// | ||
- | <WRAP center round important 70%> | ||
- | **Warning**: | ||
- | The lighthouse deck is based on an [[https:// | ||
- | The bootloader protocol is inspired by the [[https:// | + | ====== Lighthouse deck bootloader ====== |
+ | The [[projects: | ||
+ | The bootloader protocol is inspired by the [[https:// | ||
===== Interface protocols ===== | ===== Interface protocols ===== | ||
Line 13: | Line 19: | ||
- | There is two UARTs on the deck, UART0 on te Crazyflie deck interface and UART1 on 2.54mm soldering pads available for external communication. The bootloader is available on both UART. The UARTs are setup at a baudrate of 115200. | + | There is two UARTs on the deck, UART0 on the Crazyflie deck interface and UART1 on 2.54mm soldering pads available for external communication. The bootloader is available on both UARTs. The UARTs are setup with a baudrate of 113200, one stop bit, no parity. |
- | When using the UART, commands are sent on the RX line and answer will be sent back by the bootloader on the TX line. Since the bootloader and the Flash SPI bus is working much faster than the UART, there is no need for flow control. | + | <WRAP center round important> |
+ | **Warning**: | ||
- | To make sure the boorloader is waiting for a command, a break condition can be sent to the UART to reset the bootloader state. This is good to do before sending the first command in order to make sure the bootloader is not currently in the middle of a command. | ||
- | Both UART are disabled at startup, this means that the bootloader will ignore all data and break condition coming from them. To enable an UART send the byte " | + | When using the UART, commands are sent on the RX line and answer will be sent back by the bootloader on the TX line. Since the bootloader |
- | Since 0xBC is not an implemented command. The suggested sequence in order to start the communication is sending "Break condition" | + | To make sure the bootloader is waiting for a command, a break condition can be sent to the UART to reset the bootloader state. This is good to do before sending the first command in order to make sure the bootloader is not currently in the middle of a command. |
+ | Both UARTs are disabled at startup, this means that the bootloader will ignore all data and break condition coming from them. To enable an UART send the byte " | ||
+ | Since 0xBC is not an implemented command, the suggested sequence in order to start the communication is sending "Break condition" | ||
- | **Note**: There is a priority between the different interfaces. The priority is UART0, UART1, I2C. This means that I2C is always | + | **Note**: There is a priority between the different interfaces. The priority is UART0, UART1, I2C. This means that I2C is enabled |
==== I2C protocol ==== | ==== I2C protocol ==== | ||
+ | The I2C 7 bit address is 0x2F. Sending command and receiving to answer from the bootloader is done with I2C read and write transaction. | ||
+ | Starting a write transaction will reset the bootloader state and send all the bytes written to the bootloader. The bootloader will then execute the command and write the answer to a memory buffer. Starting a read transaction will read from this memory buffer. | ||
+ | For example, after sending a command that will produce a 5 bytes answer, one should start a read transaction and read the 5 answer bytes. | ||
+ | The buffer is of 15KiB. If a command is executed that returns more than 15KiB bytes, the first bytes of the buffer will be overwritten. | ||
- | ==== SPI Exchange ==== | + | All numbers are encoded in little endian. |
+ | The boot command will boot the firmware. It takes no arguments. The command instructs the bootloader to boot the firmware image, the FPGA will resets and boot on the firmware image from the flash. | ||
+ | ==== SPI Exchange ==== | ||
+ | The SPI exchange command execute one SPI transaction. On the SPI bus it asserts the CS pin, sends WLEN bytes and then receives RLEN bytes. | ||
+ | | 0 | 0x01 | SPI Exchange command | | ||
+ | | 1-2 | WLEN | Write length | | ||
+ | | 3-4 | RLEN | Read length | | ||
+ | | 5-(WLEN-4) | ||
+ | | 0-(RLEN-1) | ||
+ | ===== Flash layout ===== | ||
+ | The flash is layered as follow: | ||
+ | | Free | | ||
+ | | Firmware | ||
+ | | Bootloader | ||
+ | | MBR | ||
+ | The write protection is implemented by setting the SR1 register in the SPI flash. This means that it can be disabled by clearing the SR1 register if updating the bootloader is required. | ||
+ | ===== Firmware versioning ===== | ||
+ | The firmware is an iCE40 bitstream ((The bitstream format has been [[http:// | ||
+ | In the context of the lighthouse firmware, versions >= 1 are released version and should be in parity (or handled) by the client connecting the board in order to boot the firmware. Versions <= 0 are development version and the intention is that the client will then boot it without further check. | ||
