doc:lighthouse:setup [2019-10-09 09:37] kristoffer |
doc:lighthouse:setup [2019-11-29 14:20] kristoffer |
Line 15: | Line 15: | ||
**OSX** | **OSX** | ||
+ | The osx implementation seems to be a bit shaky, but it is possible to make it work. I used the " | ||
The paths in the triad instructions are for Windows. On Mac OSX you will find the files to update in | The paths in the triad instructions are for Windows. On Mac OSX you will find the files to update in | ||
Line 142: | Line 144: | ||
===== Space orientation, | ===== Space orientation, | ||
- | The following rotation is done from the OpenVR space to the Crazyflie | + | |
Line 150: | Line 150: | ||
- | This allows to easily orient the Crazyflie when setting up the system with an HMD. | + | The Lighthouse deck has 4 receivers |
- | While the Lighthouse deck has 4 receiver | + | |
- | The safest way to verify the orientation | + | |
- | {{:doc:lighthouse: | + | |
- | Once you have located X positive, you can test if the positioning is working by starting the Crazyflie facing X and using the clients " | + | |
