Next revision Both sides next revision | |||
doc:lps:anchor-low-level-config [2019-03-22 13:03] kristoffer created |
doc:lps:anchor-low-level-config [2019-03-22 13:06] kristoffer |
Line 18: | Line 18: | ||
- | The serial port can be opened with your favorite serial console, picocom: <code bash>$ picocom / | + | The serial port can be opened with your favorite serial console, picocom: |
+ | <code bash> | ||
+ | $ picocom / | ||
Line 24: | Line 27: | ||
Find the serial port with //ls// | Find the serial port with //ls// | ||
- | ls -a / | + | $ ls -a / |
Line 30: | Line 33: | ||
To open the serial port | To open the serial port | ||
- | screen / | + | $ screen / |
Line 59: | Line 62: | ||
- | press ' | + | press ' |
+ | Note: the node must be restarted for the configuration to be activated. | ||
