doc:lps:index [2017-04-10 13:43] kristoffer |
doc:lps:index [2018-05-11 14:51] kristoffer |
- | <WRAP center round info 60%> | ||
- | We're currently working on updating the documentation for the Loco positioning system. Util the documentation is completed you can find the old early access documentation [[doc: | ||
- | The Loco Positioning system (LPS) project is a set of hardware and software designed to implement a local positioning system | + | The Loco Positioning system (LPS) project is a set of hardware and software designed to implement a local positioning system. |
+ | * [[projects: | ||
+ | * [[https:// | ||
- | ===== System overview ===== | + | ====== Terminology ====== |
+ | To make the documentation easier to grasp there' | ||
+ | * **Deck and node:** These refer to pieces of hardware ([[projects: | ||
+ | * **Tag and anchor:** These refer to roles when ranging (i.g depending on configuration a node can act as either a tag or an anchor) | ||
+ | ====== System overview | ||
- | * ToA ([[doc: | + | |
- | * [[doc: | + | |
+ | * [[doc: | ||
+ | * [[doc: | ||
+ | * [[doc: | ||
+ | * [[doc: | ||
+ | * [[doc: | ||
+ | ===== Protocols ===== | ||
+ | * [[doc: | ||
+ | * [[doc: | ||
+ | * [[doc: | ||
- | This getting started documentation is intended to guide you from receiving your Loco Positioning Indoor Explorer Bundle to having an autonomous Crazyflie 2.0. | ||
- | ==== Tools ==== | + | ===== Tools ===== |
- | * [[doc: | + | * [[doc: |
* [[doc: | * [[doc: | ||
- | ==== Prerequisites | + | |
- | In order to illustrate how to set up a system we document a reference system and how we've set it up. The referance system is base on the [[https:// | + | |
- | make clean | + | |
- | make | + | |
- | make cload | + | |
- | Use the [[doc:lps:tools# | + | |
- | {{:doc: | + | |
- | Note; If you're not following our reference set-up | + | |
- | The position | + | |
- | The [[doc: | + | |
