doc:lps:index [2017-04-10 14:15] arnaud |
doc:lps:index [2017-07-18 14:45] arnaud [Experimental functionality] |
- | <WRAP center round info> | ||
- | **IMPORTANT** | ||
- | We're currently working on updating the documentation for the Loco positioning system. Until the documentation is completed you can find the early access documentation [[doc: | ||
- | The Loco Positioning system (LPS) project is a set of hardware and software designed to implement a local positioning system | + | The Loco Positioning system (LPS) project is a set of hardware and software designed to implement a local positioning system. |
+ | * [[projects: | ||
+ | * [[https:// | ||
- | ===== System overview ===== | + | ====== Terminology ====== |
+ | To make the documentation easier to grasp there' | ||
+ | * **Deck and node:** These refer to pieces of hardware ([[projects: | ||
+ | * **Tag and anchor:** These refer to roles when ranging (i.g depending on configuration a node can act as either a tag or an anchor) | ||
+ | ====== System overview | ||
- | * ToA ([[doc: | + | |
- | * [[doc: | + | |
+ | * [[doc: | ||
+ | * [[doc: | ||
+ | * [[doc: | ||
- | This getting started documentation is intended to guide you from receiving your Loco Positioning Indoor Explorer Bundle to having an autonomous Crazyflie 2.0. | + | ===== Protocols ===== |
+ | * [[doc: | ||
- | ==== Tools ==== | + | ===== Tools ===== |
- | * [[doc: | + | * [[doc: |
* [[doc: | * [[doc: | ||
- | ==== Prerequisites | + | |
- | In order to illustrate how to set up a system we document a reference system and how we've set it up. The referance system is base on the [[https:// | + | |
- | make clean | + | |
- | make | + | |
- | make cload | + | |
- | Use the [[doc:lps:tools# | + | |
- | {{:doc:lps:locorefdist.png? | + | |
- | Use the LPS tab of the Crazyflie | + | |
- | The [[doc: | + | |
